-   -   How do I get rid of a water stain on the ceiling? (http://forums.pelicanparts.com/off-topic-discussions/1071996-how-do-i-get-rid-water-stain-ceiling.html)
Por_sha911 09-02-2020 09:55 AM
Had a leak. Got it fixed. No mold so just a brown water stain.
Waited for it to dry and then I tried using Kilz primer but the majority of the stain just bled through. I tried laying the Kilz on heavier but after several attempts still no joy.
Calling all painters: what do you suggest? I read bleach but I'm thinking it is too late for that since it has several layers of Kilz.
MRM 09-02-2020 10:08 AM
Have you painted a layer of paint over the Kilz?
sc_rufctr 09-02-2020 10:15 AM
How big is the stain? Have you looked at it from inside the roof?
I'd leave it alone for a while and see if the stain get's any lighter. I suspect the "sheetrock" may not be fully dry from the leak.
Por_sha911 09-02-2020 10:15 AM
Just put a coat of ceiling paint on it. It is better but still showing through - just lighter than before.
Roswell 09-02-2020 10:17 AM
There are several variations of Kilz on the market. I bet you are using the newer water based low voc version. Try the oil based original. It is available in a spray can.
legion 09-02-2020 10:21 AM
1. Let it dry for a month before painting. You may even want to mark the edges of the stain with a marker to see if it is growing or staying the same.
2. Start with Kilz latex. If that doesn't work, try Kilz oil-based. If that doesn't work, try a shellac primer.
3. Apply ceiling paint.
sammyg2 09-02-2020 10:28 AM
Have you tried bleach?
I've used that on acoustic ceiling tiles ...
dad911 09-02-2020 10:36 AM
Interesting. I've never had Kilz not work. Still wet?
LWJ 09-02-2020 11:01 AM
Agree with Legion. Oil based is the ticket.
cabmandone 09-02-2020 12:50 PM
I did one coat of kilz and then just regular ceiling paint. Worked like a charm. The kilz is thing and doesn't cover well. Not sure it's really designed to cover. I think it just seals the spot and then you paint. I could be wrong.
Ayles 09-02-2020 01:10 PM
I would think if it got really wet I would cut out and patch it with a new piece of drywall and finish/paint.
cabmandone 09-02-2020 02:30 PM
I'd drink a 6 pack, cuss at it and then call someone to do the job. :D
stevej37 09-02-2020 02:34 PM
<iframe width="560" height="315" src="https://www.youtube.com/embed/wV9UKIrP-Pw" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Bill Douglas 09-02-2020 02:53 PM
Oil based Zinsser Stain Block. NOT the water based stuff.
then a coat of ceiling paint.
Bugsinrugs 09-02-2020 03:58 PM
Plus 1👌
john70t 09-02-2020 04:38 PM
Suggest using a big hole saw and spraying the inside a few times with 10 percent+ bleach solution over a couple weeks or months.
Take your time. No need to soak it and pop the drywall.
(The brown stains I assume is um from a toilet base wax ring gasket.)
Small hole patches can be fixed with one or two short 1x6 with at least a few inches overhang on both sides.
Attach plug to that. Lever it into place. A couple drywall screws on the sides no closer than 1.5" maybe.
Spackle.
Be warned the vinyl stuff doesn't sand and can leave a wavy mess when gooped on thick.
Don't be hasty, whatever you use. Also leave the primer a few days to cure.
A small bag of Easy Sand 45 or 60 needs to stirred well and rest first, and be applied with 10" or 12" trowel in a 14" square bucket. Done in thin layers it with the last very wet will need very little sanding.
brainz01 09-02-2020 04:55 PM
Agree with others: Oil based Kilz should cover it.
Also, Kilz makes a ceiling stain primer and paint in a can. My MIL bought some for an old water stain in one of her bedrooms. I had low expectations, but the stuff worked amazingly well for about 3 minutes of work on my part.
Was it as good as a fresh painted ceiling? No.
But it covered the stain and blended so well you really had to look for it.
onewhippedpuppy 09-02-2020 05:07 PM
Piling on now, water based Kilz sucks but oil based is the bomb. Many years ago I worked at a restoration company we used to spray entire house interiors with oil based Kilz wearing hazmat suits after fires.
pavulon 09-02-2020 05:11 PM
paint the rest of the ceiling brown.
peppy 09-02-2020 05:35 PM
I had to clean my computer after that!!
