Fleabit peanut monkey
78 Lincoln no spark but 12V to coil
I'm getting a little rusty so looking for confirmation/direction.
78 Lincoln has primary juice to coil but no spark when cranking. I have replaced the coil and symptoms are the same. I can replace the entire distributor assembly for $75 as well as spark plug wires for cheap. I believe the only thing left as a potential culprit would be connections and wire continuity between the distributor and coil. Any other potential areas that would cause this failure?
1981 911SC Targa |
D idn't E arn I t
Dizzy pickup?
In the movies only bad guys sleep in king size beds. |
Hell Belcho
Is there 12V at the coil while cranking? I assume you checked rotor and cap?
Points or ignition pickup?
Saved by the buoyancy of citrus. |
Control Group
Whatever it is, when you figure it out, it will piss you off you did not get it immediately.
Points, that is as bad as mechanical injection, and I had both of them, that little Pertronix thing is the bomb.
She was the kindest person I ever met |
Functionista
You have 12V to the coil but, using a test light, is it pulsing while cranking?
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
I have to assume it's the distributor pickup, and could be as simple as a poor connection. Cap rotor look ok, used but nothing awful. I suppose the distributor to coil secondary wire could be bad but easily tested. I can test everything individually but for cheap I can replace the complete distributor assembly with new.
1981 911SC Targa |
No points. Reluctor and magnetic pickup.
1981 911SC Targa |
Still Doin Time
Isn't that a EEC system with a module?
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Oh boy. Lemmie check.
Edit: You are correct, Sir! I will pull it and do the smell/shake test. I still may just replace it for $40 if it appears good. Summit Racing has Motorcraft for $62. Right down the street. Edit #2: Found procedures to test module. Thanks guys!
1981 911SC Targa Last edited by Bob Kontak; 09-06-2020 at 09:17 AM.. |
Functionista
Yep, module is next after confirmed pulse.
Yep, module , done hundreds of them over the years, you need a special tool, or have to ground down a socket to fit in there . I think its 9/32" ??
No left turn un stoned |
I stand corrected, that is the old school one where the module is a separate unit . Probably still your failure though . A bad jump start, or electrical spike would take them out.
Sweet! Thank you all!
Owner did a lot of jump start attempts and he's genuinely not a car fix guy.
1981 911SC Targa Last edited by Bob Kontak; 09-06-2020 at 10:41 AM.. |
I cannot get a pulse.
If I connect the test light leads between coil positive and negative battery terminal the light stays on while cranking. If I test positive coil to negative coil I get no light at all. Not with key on or while cranking. I don't understand if I should get the light/pulsing light in this test scenario.
1981 911SC Targa |
You do not have permissi
20,000 volts or whatever would normally pop that little bulb in a second.
Meanwhile other things are still happening. |
Functionista
Functionista
Or does this have the separate fender mounted module with, like two plugs? Maybe check connections there first...
Functionista
Unplug the ignition coil, put a test light between the 2 connectors and crank the engine, the light should flash, if it doesn't replace the ignition module, if it does then replace the ignition coil.
Edministrator
Curious what model Lincoln?
Good post? Leave a tip! O - $1 O - $2 O - $3 |
Mark V and it's beautiful. Fully one quarter of a mile long. I'll get a pic on the next visit.
If I move the test light ground clamp to the negative battery terminal I get steady on with no flashing.
1981 911SC Targa |
