-   -   Curious Who Uses Walmart / Super Tech Oil? (http://forums.pelicanparts.com/off-topic-discussions/1073224-curious-who-uses-walmart-super-tech-oil.html)
slow&rusty 09-16-2020 04:04 AM
Curious on if any of you use the Walmart branded oil (Super Tech), blended / distributed by Warren Oil Co.
I've been using it recently on an old engine that had been sitting for a while just to get a few hundred miles before a 2nd and 3rd oil change rather than the more pricey stuff.
legion 09-16-2020 04:12 AM
I use it on my Mustang. Considering that it takes 8 quarts, I drive it 1,000 miles a year, and I have to change the oil every year, it makes sense to use a relatively inexpensive oil.
2.7RS 09-16-2020 05:27 AM
I've used for decades on all my ford products.
Some of them reaching 300k
I change oil every 5k
JackDidley 09-16-2020 05:38 AM
I use it in my truck. Still use Mobil 1 in the Cayman.
<iframe width="1280" height="720" src="https://www.youtube.com/embed/zwqt5vI0o1A" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
1990C4S 09-16-2020 05:40 AM
^^^ He is slightly annoying, but he does some interesting stuff.
vash 09-16-2020 07:53 AM
i dont remember the last time i was in a Walmart.
they run the lighting at depressing levels for me..
GH85Carrera 09-16-2020 08:02 AM
It has been over 20 years for me. I just hate the place. I am really afraid someone will take my picture and post it on the WalMartians web site!
My two cars are both 1980s cars with flat tappets. I use Brad Penn in both, only now it has a new name. 372,000 on the El Camino and 176,000 on the 911.
I am not using any Wal-mark oil in my car. YMMV.
Evans, Marv 09-16-2020 08:08 AM
I use their oil for diesel engines in my little, old tractor. I change the oil & filter pretty frequently since the hour meter doesn't work. I use RPM Delo in my larger tractor. When I had my truck, I used synthetic in it. I don't think I would have ever considered using Super Tech in the truck, although it may be good oil.
Baz 09-16-2020 08:31 AM
225K miles on the '02 Silverado.
Super Tech every oil change since I bought it in '05 with 90K miles.
porsche tech 09-16-2020 09:22 AM
I buy a 5 quart jug of 0/20 Mobil 1 at Walmart for about $25. I saw Costco now has Kirkland synthetic motor oil...curious who makes that for them. I like Walmart...buy a lot of groceries there too.
red-beard 09-16-2020 09:27 AM
I use Amazon Basics Synthetic which is also Warren oil. I use it in my Ford F250 and in the Air Cooled Generators I support.
Arizona_928 09-16-2020 09:36 AM
I use the walmart sythetic in gasoline generators, air cooled gas single and twins, and gas domestic trucks. I use the rotella t6 in all diesel applications.
Just change it regularly....
unclebilly 09-16-2020 09:55 AM
I use the TDH and hydraulic oil in some old farm equipment. It seems to leak no different than the more expensive stuff...
speeder 09-16-2020 10:17 AM
I once went to look at a motorcycle for sale in the San Pedro area of Los Angeles. This is where the major refineries are located and the seller was an engineer at one of the major refineries.
I asked him what brand of oil he used and he said, “whatever is on sale.” He then showed me how to read an oil bottle or container. He pointed to the front and said, “all of this is irrelevant...” while pointing to words like, “turbo approved” and “high mileage...”
He also said that the brand was irrelevant. He then pointed to the “donut” with the viscosity and letter rating and said that was the only thing that mattered. SG, SH, SM, etc... Everything else was BS, according to this engineer from the refinery. I did not wind up buying his bike, which was probably a mistake since he took care of his stuff like few people I’ve ever seen.
Take that for what you will.
1990C4S 09-16-2020 10:34 AM
The rating is the floor, presumably the 'higher end' oil exceed the standard.
Or it's all a scam.
I'm cheap but I don't skimp on oil. Maybe on my son's car. Not on mine.
And the small savings on my single cylinder air cooled stuff isn't worth the effort.
1980SC 09-16-2020 11:14 AM
I've run it in a few of my cars for probably 20 years or so. Haven't had a problem yet.
Eric Coffey 09-16-2020 12:05 PM
Rating index is important for ID'ing the "minimum" quality standards, as mentioned above. There are many different variables and some pros/cons within them. Basically, the type and quality of the base oils + the type/quality of the add-pack/viscosity modifiers, etc. Another thing to look for is additional car manufacturer ratings. These are typically more strict (BMW LL-X, MB 229.X, etc.). If a particular oil meets several of those as well, then it's probably a safe bet regardless of the brand. Though, some of those 3rd-party ratings are application specific (diesel engines, etc.), and there is a big push towards fuel economy these days. So, "higher" ratings don't necessarily mean "better", and it's good to know what's what.
Here is an interesting tool for a basic/crude comparison between the different rating standards.
red-beard 09-16-2020 03:08 PM
Sammy? :D
red-beard 09-16-2020 03:14 PM
On large engines, the type and brand and additive package can make a big difference. We switched from a very good Shell Product to a Phillips 66 product and were finally able to get 1000 hours between oil changes. It also burned less oil and prevented cylinder silica buildup. At $8/gallon, each oil change is about $1,200.
Yep, $1,200 in oil every 6 weeks. And $1,600 in spark plugs...The oil filters are cheap at $35 each...about $25,000 per year...per engine.
speeder 09-16-2020 03:52 PM
What type of engine/application is that? I did not realize that anyone made gasoline or spark engines that large(?)
speeder 09-16-2020 03:58 PM
Or it's all a scam.
Don’t get me wrong, guys, I do not believe in using inferior oil. My argument was that the no-name stuff is probably just as good in a lot of cases. And for any car I service that specifies manufacturer rating, I NEVER deviate from it. For my VW TDI, (which calls for a very specific VW spec oil), I use Liquimoly or similar European brand. Same w BMWs, Audis, etc.
I think we are in agreement for the most part.
Shaun @ Tru6 09-16-2020 04:04 PM
I have always used name brand oil. Piece of mind is better than the pennies I save over cheaper alternatives.
Shell Rotella T6 Diesel oil in a gas '94 E320
http://forums.pelicanparts.com/uploa...1600301025.jpg
red-beard 09-16-2020 04:26 PM
These are "natural gas" Engine-Generator sets. And they are not the largest that CAT makes.
Each unit is 1.6MW ~ 2000 HP. G3520C. The G3600 series are 4MW.
We actually run them on low BTU landfill gas.
