Induction cooktop
Seems to be the rage lately and I’m not sure why. Does it heat more evenly than gas or electric glass cooktop or is it for convenience or safety? What do you know about induction cooking?
Heats fast, very very fast, no fire to burn the house down. I think heats evenly too? Only work with a certain pots and pans
Yep, it heats quickly. I think it requires ferrous pots because it uses some sort of electro-magnetic induction to heat. I think it also cools off very quickly.
https://www.consumerreports.org/electric-induction-ranges/pros-and-cons-of-induction-cooktops-and-ranges/ Quote:
Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa ![]() |
"it's difficult to hit a precise temperature with gas ranges."
I have to disagree.
We're trying it out - got one of those chinese single 220V/3500W "catering" burners. It's not the finest quality but it was ~25% the price of the Volrath USA unit.
It still feels like cooking with magic. Much faster to boil a big pot of water than our gas cooktop. A friend blew me away when step 1 of frying bacon was to cover his induction cooktop with newspaper to keep it clean. It baffled my 45-years-of-cooking-with-gas brain! One neat thing it can do that gas cannot is that you can set a temperature and it'll hold it there. It makes things like deep frying nearly idiot-proof.
'78SC, lots of other boring cars... |
IKEA sells an induction cooktop that’s not too expensive. I might pick one up for my camper trailer to try out. I know it uses quite a bit of power so I’ll only use it when I’m connected to shore power.
We have been using an inductive cooktop for several years. While you can induct a magnetic field into most any metal,you will want to have a set of stainless steel pots and pans in order for it to work properly. For the most part, I like the inductive cooking, but the next time I buy a new cooktop, it will be inductive/radiant.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
We've had an induction stove for 7 years and love it. It's the most energy efficient system, boils water very fast, and is easy to control. And it's very easy to clean. Ferrous pots and pans are easy to find.
Charlie 1966 912 Polo Red 1950 VW Bug 1983 VW Westfalia; 1989 VW Syncro Tristar Doka |
A surprise was that our All Clad MC2 (?), the ones with the raw Al exterior, weren't compatible. The more normal shiny SS exterior AC were good to go. Same problem with our webstraurant-cheap Al nonstick skillets, but that just means the next ones will be $18 instead of $14. I've used induction heating industrially for years and I understand it perfectly well, but still I giggle at using "magic" to cook at home. It's like the exact opposite of my "well, nobody _really_ needs hair on the back of their fingers and hands" outdoor wok burner.
I bought a portable one at one of those Chinese market for 45 bucks. I use it at my job site to heat some food and such. Its been through hell and still works fine. Had it for couple years now. If I were to re-do my home, that's what I buy without thinking twice about it.
I have a Bosch induction cooktop and love it. It heats very fast and evenly, and can hold a low simmer very well.
We went from Gas to Induction, I like it better, way easier to clean. Some ceramic type frying pans seem to heat differently, I am guessing the amount of iron in the aluminium pan varies between manufacturers, so level 6 on one pan can be like level 5 on another pan, cast iron always works well, pretty consistent heat across the entire pan surface with any pan.
The amount of power capable will very between cooktops, usually there is at least one pot surface with really high power for boiling water really quick, or called a boost function. One interesting thing I found on ours (Bosch) is the perimeter of the glass itself supports the unit and everything on it, not sure how hard a hit with a cast iron pan before it would shatter and everything goes down.
87 930, Last edited by 908/930; 09-27-2020 at 01:19 PM.. |
I need one to low simmer on, my gas cooktop has plenty of power but no true just bubbling simmer burner. Wondering if you can put a non induction saucepan on an induction capable pan to transfer the heat?
Thinking a single standalone.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
I took have the Bosch and really like it, have some USA made All Clad pans that work wonderfully. Also use my cast iron on it with good results.
Induction is much better from both safety and energy viewpoint. It only heats the actual metal, not the glass and it is much quicker/powerful than other electric means of heating. Pros: - glass top is only heated indirectly by pans on in. So spilled food is much easier to clean off as it is not "caked in" by the heat. - Safety: unless you have something magnetic on it it will not heat up. So no issues with acciddentaly placing stuff on the hob which is turned on. You can place your hand on it and turn it to 11 and ... nothing happens. - Energy efficient: less heat spill. Cons: - Creates overtones in wiring and can draw a s**tload of current. - needs magnetic cooking wares. Aluminium does not work (this is somewhat af a non-issue nowadays as almost all pans are compatible with induction. - "heating" is done by power electronics. It needs fans to keep it cool.
Thank you for your time, |
Nothing but gas for me. Can't stand any form of electric cooktop.
I've been curious, and trying to sell the missus on induction. Based on this and other threads here over the years. She's game, but said "I'd like to try it out before we go all-in."
So I bought an induction "hot-plate" off of Amazon. You can get them as cheap as $50, but I was concerned that buying a cheap one might provide a bad experience. I spent a bit more ($150) and got one that I think we could use on holidays or whatever over the years. I was also a little concerned that the function of a 120V may not be good compared to a full range running on 240V. And while I know that it is more limited, I figured it would be good enough for a lot of stuff. I got it today. First, I steamed some dumplings. It was only 1/2" of water in the bottom of the steamer, but it boiled FAST. Even faster than on the stove on a large burner on full power. Then later, I cooked some sausage and a couple of eggs. It seemed to work really well for all of the cooking. I put the cooktop on a small unfinished wood table that the PO of the house left. The tables not much to look at, but to try to keep it from getting worse, I put a big sheet of packing paper over the cooktop which also covered a bunch of the table. The paper is basically news paper without any printing, and it was between the pot and hot plate. The paper looked completely normal after cooking other than being covered in grease splatter. When everything was hot, I was able to touch the cooktop near the pan and it was cool. That's impressive. One thing that I'd read and seen photos of was that for these 120V hotplates, the actual magnetic field size is always about 4.5" ±.25" and people complained that the center of their pot would be hot and burn while the outside was not hot. I assume a full size stove/cooktop isn't like that. Also, I assume that using better pots and letting the pots heat up eliminates that problem. I didn't notice any issues when I was cooking. I'm curious to see what the missus thinks. She frequently makes large batches of chicken broth/stock. I'm not sure how well this little hot plate will do with a really large pot of water. Again, I suspect the quality of the pot will have some impact on that. I'm sure a large 240V cooktop would do a much better job.
I see the benefits of gas, and good gas range (like Wolf) has twin function burners (heat or simmer), but I would prefer a glass cooktop that was easy to clean.
A gas stove with a messy cook is a nightmare to clean. I do it a lot.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
We had a really nice cooktop. It was the 2nd most expensive of the Kitchenaid Architect series, IIRC. It lacked 2 things from the most expensive model, lights that showed that a tap was on and a special coating that made cleaning the stainless easier. Yeah, we'd have really loved to have had that special coating.
And the quality of the pot seem to have a lot to do with how well it cooks. We've got some Demeyere stainless (Atlantis and Proline). Also, when we first got this place, and were maintaining 2 residences, the kids gave us a few of their old REALLY cheap pots (like "as seen on TV" type stuff).
I just tested an equal amount of water (about a pint) set to boil in a Demeyere and on of the cheap sauce pots. The Demeyere was at a full rolling boil in 2 mins with no indication of a hotspot on the bottom of the pot (the whole bottom was boiling, not just a ring in the center). The cheap pots which are enameled thin aluminum with a thin ferrous steel disk on the bottom didn't boil until 4 minutes and had a noticeable hot spot (the boiling started in a spot about half the diameter of the pot). We've got some old cast iron and also some LeCrueset enameled cast iron, but I think all of that is in storage, unfortunately, so I can't test those. I assume they should work similar to the Demeyere.
