-   -   Need help with using my multimeter (http://forums.pelicanparts.com/off-topic-discussions/1074935-need-help-using-my-multimeter.html)
gsxrken 10-05-2020 01:43 PM
I’m trying to test the resistance of my auxiliary air regulator AAR, and I can’t make sense of the readings. If I use the meter like the directions say, on the 200 (omega) I get nothing. Just a 1. Same on any of the other settings, just a 1... except on the 2000k setting, where I get somewhere around 496, 520 to and it climbs up as I watch it.
What is the resistance of this thing? I think the spec is around 35... is that 35/350/3500/350000 depending on what setting I’m on? Damn my head hurts.
http://forums.pelicanparts.com/uploa...1601930514.jpg
red-beard 10-05-2020 02:16 PM
I believe you are pretty much reading open circuit, with a TINY amount of interference.
aschen 10-05-2020 02:20 PM
open circuit
500k is basically the plastic or insulation or the charred remains of whatever let the smoke out
ledhedsymbols 10-05-2020 03:15 PM
I agree with the other posters. Some multimeters display a 1 for "out of range."
gsxrken 10-05-2020 03:45 PM
Well you guys were all correct. I drilled out the rivets to see what could be seen, and lo- one of the wires had broken free of the post.
A quick soldering iron job and I now have 21.x in resistance (using the manuals recommended 200 range.
Thanks guys!
http://forums.pelicanparts.com/uploa...1601937915.jpg
wdfifteen 10-05-2020 03:48 PM
Excellent! Now put it back together and get out there and finish that lawn!
