Need help with using my multimeter
I’m trying to test the resistance of my auxiliary air regulator AAR, and I can’t make sense of the readings. If I use the meter like the directions say, on the 200 (omega) I get nothing. Just a 1. Same on any of the other settings, just a 1... except on the 2000k setting, where I get somewhere around 496, 520 to and it climbs up as I watch it.
What is the resistance of this thing? I think the spec is around 35... is that 35/350/3500/350000 depending on what setting I’m on? Damn my head hurts. ![]() ![]()
Ken 1986 930 2016 R1200RS |
canna change law physics
I believe you are pretty much reading open circuit, with a TINY amount of interference.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
open circuit
500k is basically the plastic or insulation or the charred remains of whatever let the smoke out
84 930 18 Cayman GTS |
Serial Lurker
I agree with the other posters. Some multimeters display a 1 for "out of range."
Well you guys were all correct. I drilled out the rivets to see what could be seen, and lo- one of the wires had broken free of the post.
A quick soldering iron job and I now have 21.x in resistance (using the manuals recommended 200 range. Thanks guys! ![]()
Excellent! Now put it back together and get out there and finish that lawn!
