Well by that measure every system on every car ever made can be considered problematic.
I used to wince when I operated the top and all of the popping and banging started. If you've never sat in one and operated the top, your first time it will get your attention. |
Have always loved this feature on all of my W124s
http://forums.pelicanparts.com/uploa...1602351541.jpg http://forums.pelicanparts.com/uploa...1602351541.jpg |
I always liked the looks of the W124. One of Bruno Sacco’s finest designs...
I liked that color when they came out with it, too. |
well go ahead and change the headlight unit on that modern Merc . Have fun with it cause the benefit of that fancy hood won't help you do that job, at all.
Maybe a coincidence but the transmission on my 90k D2 S8 failed about 1,000 miles after I changed the transmission fluid and filter. Pretty sure it had never been changed.
Yeah, that is what concerns me. What exactly failed inside your transmission?
Valve body?
I loved my A8, but what sent it to the donation yard was, believe it or not, a starter. Was like a 1500 job, on top of control arms (unrelated) and a bunch of sensors that lit the dash up but meant nothing. It was a great car until 180k, and then it imploded all at once.
http://forums.pelicanparts.com/uploa...1602380272.jpg http://forums.pelicanparts.com/uploa...1602380272.jpg |
I think the W124 is a timeless design. I wish I had bought a 500E when they could be had for under $20k.
You and me both. I’d love to have a 92 model. I’m a bigger fan of the pre-face lift cars, I think.
Flare and then bang into gear, particularly bad from a start. The worst was starting on an incline where the car might roll backwards slightly, when I applied throttle it would slip and then bang into gear. It also did that on a stop on an incline. It also would flare shifts but that was intermittent. I believe it was worse when hot. In tiptronic mode it was far better behaved, far worse when driving in automatic.
http://forums.pelicanparts.com/uploa...1606069030.jpg |
Mercedes makes it easy when doing a motor swap! this is my 84' 280CE that I pulled the seized M110 motor and swapped in a turbo diesel OM617a in to.
http://forums.pelicanparts.com/uploa...1606070114.JPG http://forums.pelicanparts.com/uploa...1606070114.JPG |
| All times are GMT -8. The time now is 03:39 AM. |
