Male to Male Electrical connector
I am in need of a male to male connector. Can't find one. Thinking about making one. Anyone done this before? Is this a fire hazard?
Sounds kind of gay......not that there's anything wrong with that.
What are you connecting?
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
It'll be connector of the year!
Do you mean two female connectors wired together, or two males? Cause two male connectors leave exposed charged contacts.
Platinum Member
Do you mean for line voltage? I don't see a reason to do so, as it can have live prongs exposed.
My guess is you're trying to patch a generator to your house, and there are safer, less dangerous ways to do so.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
^ suicide plug.
You need to make your own. |
Model Citizen
I'm assuming this is for the christmas lights that you strung with the wrong end the wrong way.
Take your losses, get that ladder back out and turn the string of lights around.
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
One of these?
![]() Edit: See Alan's post. |
FUSHIGI
Cults require delusions. |
Thanks guys, yep friggin Christmas lights......
Isn't that called a "wire"?
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Cut the ends off and put new plugs on each end.
Rutager West 1977 911S Targa Chocolate Brown |
I was racking my brain trying to imagine why anyone would want to do this. Good call!
It is not a fire hazard. It is an electrocution hazard.
Location: behind the redwood curtain, (humboldt county) california
not a good idea
The problem with this approach is that when plugged in, the lights will go on, but you will have the male end floating about and that bare hot side of the plug could give someone a very bad, potentially lethal shock.
merry x mas, chris Sorry rwest, i missed " each end" still probably faster to just unwind the lights, or get an extension to plug it n normally Last edited by chrismorse; 12-06-2020 at 07:17 AM.. |
D idn't E arn I t
![]() rjp
In the movies only bad guys sleep in king size beds. |
video when trying it out?
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Platinum Member
Here’s a little experiment with a double male plug.
Evil Genius
meh, it's only 120vac, it'll give you a tickle and that's about it.........soda can is just a stunt.
The speaker is a fair test..........if the speaker is rated at 1200 watts, it won't fry......call line power just a 60 hz tone.
Life is a big ocean to swim in. Wag more, bark less.
