How do I use the electric connector?
A buddy that works at MSD gave me a pile of these. He says they are waterproof and vibration proof. Seems like the perfect option to use on my kayak to allow me to swap batteries. I can use one of these at each battery and swap batteries with one pigtail to my appliance.
Do you just push the wire into the tiny hole? I dint have that many to guess. I tried to text my buddy. No answer. Please see pics. ![]()
poof! gone |
Hell Belcho
Lets see the other, non orange ends...
Saved by the buoyancy of citrus. |
I believe that there are small pins that the wire is connected to before inserting the pin into the holder. There is a special tool made to remove the pins from the plastic housing. I don't think you can get them out without the tool. Not sure how waterproof they will be. The ones that are really sealed have a rubber seal on the male end of the connector.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Brew Master
You have to buy the small pins. You crimp the pins on the wire then the pins snap into the connector. It's a molex connector or something like that.
As for the pins and removal of them, it depends on whether that connector uses the round pin or the one with a small tab that locks it in once inserted. I've seen and used both. If you pull the orange rubber piece out, you should be able to tell what style of pin that connector takes.
Nick |
Look up Pin and sleeve, You will need to find ones that fit. Make sure the amperage is rated for what you are using it for, and fuse at the battery. Something like McMaster Carr 9171T41, I am not sure if that one will fit your plug.
87 930, Last edited by 908/930; 12-08-2020 at 05:58 PM.. |
Just thinking out loud
I don't think that connector is going to be safe for any successful fishing expedition on your kayak. Too much voltage going through the wire. Read more here.
https://www.techwalla.com/articles/how-to-make-a-fish-shocker
83 944 91 FJ80 84 Ram Charger (now gone) |
Found out why my buddy was not responding. He has COVID. On the mend, but still coughing. El Paso tx
poof! gone |
Now the owner at MSD is asking why he’s short electrical connections...😂
They are Deutsch DT series waterproof connectors
You really should use the correct crimper, it will double crimp the pins correctly. Otherwise, don't consider it to be at all waterproof. Looks like 20-25 amps at 12V is their limit, dunno what your kayak pulls. They go for about $6-7 for each complete connector on Amazon.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Electrical connectors on a KAYAK! There is no sport in that. He's already stealth. It's not fishing if you have a fish finder, trolling motor, etc..., on a KAYAK! Shock the fish already! He has built a net that can gather enough for a fish fry.
