Gravity Industries - Cool or Insane?
Jetpacks!
https://gravity.co/ Scroll toward the bottom of the following link for jet pack specs: https://gravity.co/experience/ |
Cool to watch someone else do it
Interesting. I think if I could choose, I'd prefer the jetman setup more.
![]() But I wouldn't turn down a chance at using either.
I see you
Beta testing is always a necessary step. I'm not able to imagine a solution to the range issue as fuel capacity would seem to be a big problem, but it sure is cool.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
The landing gear is pretty fragile!
I hope the throttles are not set up where he grips hard and they go wide open.
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
I can only imagine the " hey hold my beer " moments with that setup
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Per the video (I didn't watch the whole thing) the triggers are not like a rheostat, gas pedal or motorcycle throttle. They are on or off. Like I said, I didn't watch the whole thing, but he said that you squeeze the trigger a second time to bump the thrust up a notch. I didn't hear what the process was for throttling down.
You mean like "Hey! Let's see if I can light your cigarette with this thing!?!" Or "you're cold? I can fix that!" Or maybe "Want a Brazilian, I can do that quick."
Platinum Member
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
As I understand the throttle:
One hand sets the thrust level in digital increments (click up / down to increase / decrease thrust level). The other hand changes the power output setting from idle to the set thrust level (pull trigger to go from idle to the preset thrust level). |
