A930Rocket's Avatar
What adhesive what I use to bond aluminum to a bumper cover.
What adhesive what I use to bond aluminum to a bumper cover?
The bumper cover on my BMW has a very short flange where it meets the fender. I was thinking about cutting notches for the contour and bonding a thin piece of L-shaped aluminum to extend the bumper flange.
What is the best adhesive to adhere the aluminum to the bumper cover?
I’m at Lowe’s, so if anybody has a quick answer, let me know.
Thanks!
Old 01-03-2021, 09:53 AM
Non Compos Mentis
Probably J-B Weld
Old 01-03-2021, 10:02 AM
Rubber cement
Old 01-03-2021, 10:16 AM
Model Citizen
herr_oberst's Avatar
pop-rivets
Old 01-03-2021, 10:23 AM
Arizona_928's Avatar
Originally Posted by Dantilla View Post
Probably J-B Weld
+1
Latest jb weld adventure was to use a strip of aluminum can to patch a hole in a light tower spot light dome. Works.
As for your case 90mph tape. ..
dolor et pavor
Copyright
Old 01-03-2021, 10:43 AM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
Puraflex40
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 01-03-2021, 11:24 AM
Two part urethane adhesive.
Old 01-03-2021, 12:17 PM
Bland
unclebilly's Avatar
3M DP8005 is what you want. Remove the oxide from the aluminum first with clean sandpaper and follow the directions. This was formulated for bonding low energy materials such as this.
Old 01-03-2021, 07:04 PM
D idn't E arn I t
RANDY P's Avatar
JB weld or windo weld
In the movies only bad guys sleep in king size beds.
Old 01-03-2021, 07:08 PM
Bill Douglas's Avatar
Whatever you choose, get the aluminium (probably plastic too) VERY clean with paint thinners or acetone. And as Billy said rough it up with sandpaper to get the oxide off and to give the glue something to hang on to.
Old 01-03-2021, 07:38 PM
A930Rocket's Avatar
It’s not a total beater, but a possible track car, so I tabled the pop rivet idea and wanted to go with a permanent but hidden system.
For now, I used #6 st st machine screws with washers and nuts. There just isn’t a lot of meat on the bumper cover lip to work with.
Are you guys talking about the two part JB Weld epoxy or the old standby black and white mix.
For extra adhesion, I was going to drill small holes in the aluminum.
Old 01-03-2021, 07:41 PM
Originally Posted by Arizona_928 View Post
+1
I did the EXACT same repair on my Allmand Brothers Maxi-Lite. It still holds 8 years later.
Old 01-03-2021, 07:50 PM
Bland
unclebilly's Avatar
There is bumper cover adhesive specifically for repairing bumper covers. Go to NAPA and get some or order it online...
https://www.amazon.com/J-B-Weld-50139-Plastic-Adhesive/dp/B01IBOK7FE/ref=sr_1_3?crid=3O4U29SWJ2IUT&dchild=1&keywords=bumper+cover+repair+kit&qid=1609734252&sprefix=Bumper+cover+re%2Caps%2C261&sr=8-3
Old 01-03-2021, 08:25 PM
Embraer's Avatar
https://www.3m.com/3M/en_US/company-us/all-3m-products/~/3M-Panel-Bonding-Adhesive/?N=5002385+3293241847&rt=rud
-mike
Old 01-04-2021, 03:34 AM
A930Rocket's Avatar
Originally Posted by unclebilly View Post
I just favorited that an hour ago.
Old 01-04-2021, 08:06 PM
