bye bye belt
Starting the Fit this morning at zero degrees..as soon as it fired up, I hear a 'snap'
Battery light on...can mean only one thing....serpentine belt kaput.
Didn't have a 'serpentine belt tool'...so I had to rig a substitute. I was doing the job by myself..so I didn't have any extra hands.
I ended up using a box end wrench with a 7" piece of wood to pry the tensioner back and hold it, while I threaded the belt on.
Had it most of way there but needed to turn the engine to get it seated all the way over.....which went easy with a socket on the flywheel and a long extension to a breaker bar.
There isn't much working room on that end of the Fit engine.
I have 235K miles on the car....not bad for the original belt.
Will be the last one for this car.
To pick-up the new belt...I had to take my Prelude out into the snow, sand, salt...twice.
Got lots of looks..."Wth are you doing driving that now?"
Anyone else have the belt give out when starting?
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 02-18-2021, 03:49 PM
Brew Master
cabmandone's Avatar
Yeah, I'd say you got your money out of that belt. I change mine at 100K just because I don't want to have what you had happen, happen.
Nick
Old 02-18-2021, 05:14 PM
Non Compos Mentis
I replace belts and hoses at 100k and keep the old belt as a spare.
My Jeep is about to hit 200k, time to replace them again.
Old 02-18-2021, 05:29 PM
AutoBahned
RWebb's Avatar
only 235,000 miles and it lets go - that's why Porsche rejected belts on the 911 motor and went with chain drive...
Old 02-18-2021, 05:31 PM
Brew Master
cabmandone's Avatar
Don't let your fan drive belt on the 3.2 know Porsche rejected belts! It'll hurt the pore thing's feelings.
Nick
Old 02-18-2021, 05:36 PM
Bill Douglas's Avatar
A fail. I hope Mr Honda and the boys don't read this, they'll be falling on their swords out of embarrassment.
Long live the Fit.
Old 02-18-2021, 05:37 PM
Shaun @ Tru6's Avatar
I thought this was a failed NYear's resolution diet failure thread. Glad your pants still "Fit," bad pun intended.
Tru6 Restoration & Design
Old 02-18-2021, 05:44 PM
About two years ago when it was approaching 200K miles...I figured I would replace the car soon. With that in mind...replacing stuff because it might break, doesn't seem as important.
The car has really served me well. Fun to drive, 40 mpg, and super reliable.
The serpentine belt on the Fit also drives the water pump. So, I knew that wherever it broke, would be where I would have to fix it. Luckily, it was in my driveway.
98 Honda Prelude
22 Honda Civic SI
Old 02-18-2021, 05:45 PM
Good skills both Steve and Honda.
A mechanic friend pointed out a VW engine that had only done about 40,000 miles and the belt broke damaging the engine. He said look at the cam it's turning and look at the puny belt trying to turn it.
He went on to say he hadn't seen a Corolla belt break, and they look twice as big and strong.
Old 02-18-2021, 05:59 PM
Just this last fall, I brought my Prelude into the dealer for the 75K timing belt replacement.
I had gone over the mileage and I was getting worried about the potential damage if it did break.
The Fit belt breaking is just an inconvenience...unless a person keeps driving with it broken.
When the mechanic finished changing the Prelude timing belt...he gave me the old one.
It looked brand new.
98 Honda Prelude
22 Honda Civic SI
Old 02-18-2021, 06:07 PM
craigster59's Avatar
I thought this would be a thread about suspenders....
Old 02-18-2021, 06:14 PM
I'm guilty of not wearing a belt..a lot of the time.
But, I'm sure I'll never wear suspenders.
98 Honda Prelude
22 Honda Civic SI
Old 02-18-2021, 06:17 PM
Edministrator
Steve Carlton's Avatar
With 235,000 miles, you probably need new suspenders.
Good post? Leave a tip!
O - $1
O - $2
O - $3
Old 02-18-2021, 06:30 PM
^^^ Or new pockets....as in door pockets. The Michigan winter white salt roads are getting to the 11 year old thin body.
98 Honda Prelude
22 Honda Civic SI
Old 02-18-2021, 06:38 PM
Long live the Fit.
Honda has a recall out for all the Fits owned in the northern states where salt or chemicals are applied to the road. I received my letter...but the parts aren't in yet.
They are replacing front axles because the paint isn't holding up under the rubber boots on the axle...causing the chance of them rusting and breaking.
Eleven year old car and they are going to replace both of mine and a free rental car is included. More than I would expect from a car company.
98 Honda Prelude
22 Honda Civic SI
Old 02-18-2021, 07:38 PM
SCadaddle's Avatar
Wow. I had to look up when the last of the Honda Prelude's were built. Wiki says 2001......
All the Subaru's I've owned over the last 25 years spec'd the timing belt replacement at 105K miles or 105 months. I've replaced more of them based on them running out of "time" vs. mileage. I'd say you were very fortunate on your Prelude!
Old 02-18-2021, 07:42 PM
^^^ Mine is a 98...I am the original owner. And it's always been garaged.
It currently has 120k miles.
98 Honda Prelude
22 Honda Civic SI
Old 02-18-2021, 07:47 PM
A honourable car company.
AND fantastic cars!
Old 02-18-2021, 07:50 PM
Brew Master
cabmandone's Avatar
The real question is, did you put the belt on starting from the left or the right?
How do you put your belt on?
Nick
Old 02-19-2021, 03:37 AM
A pic from Nov. last year. It still looks good from this distance, but when you are closer you notice the brown rust on the door bottoms.
98 Honda Prelude
22 Honda Civic SI
Old 02-19-2021, 04:18 AM
