-   -   Need to rent a digging tool - what to get ? (http://forums.pelicanparts.com/off-topic-discussions/1087889-need-rent-digging-tool-what-get.html)
rfuerst911sc 03-07-2021 02:49 PM
So I have hand dug with pick and shovel a drainage trench , so far about 40 feet. It is approx. 16" wide and about the same depth . But my back is waving the white flag 😩 and I have about 60' more to go .
Is a mini back hoe the proper tool ? I need it to be as small as possible due to space restrictions . I am running plastic drain pipes for gutters to drain into AND use the trench for rain runoff . Will be filled with gravel . Any advice on what tool is best is appreciated as I have never done this before .......... and hopefully never will again 😁
gregpark 03-07-2021 02:57 PM
http://forums.pelicanparts.com/uploa...1615157823.jpg
Rent a trencher
Evans, Marv 03-07-2021 03:06 PM
^^^ Good choice. Also if you are going to use the trench for drainage, get some fabric (landscaping ?) from H.D. or wherever and liine the trench with it, lay your drain pipe and fill the fabric lined trench with your gravel. Overlay the fabric over the top of the trench & spread a couple of inches of gravel on top.
VINMAN 03-07-2021 03:18 PM
If it needs to be 16" wide, I'd go with the mini excavator. A trencher/ ditch witch is only a few inches wide.
look 171 03-07-2021 03:23 PM
That thing above or a small chipping hammer. Don't rent the big and heavy one jack hammer, because moving that damn thing all day will hurt but the added weight is nice as it cuts into the soil. Rent a spade or shovel bit with it. Use a narrow shovel to scope the soil out. Easy and the 60' will be done one afternoon. Its more work to shovel the dirt out then it is to dig. No more fooking pick unless you want to lose weight and get 6 pack?
https://www.tools-plus.com/bosch-rh1255vc.html?gclid=CjwKCAiAkJKCBhAyEiwAKQBCkopr9N ZJZ8LmXvfoS4ZvRW9Ci3DVaGfY_XTkM06XDEJM160KI9f6yRoC hJUQAvD_BwE
Here's the bit, get the longest one possible.
https://www.harborfreight.com/4-12-in-sds-max-type-clay-spade-bit-60414.html?cid=paid_google|||60414&utm_source=goog le&utm_medium=cpc&utm_campaign=&utm_content=&gclid =CjwKCAiAkJKCBhAyEiwAKQBCkhQM3uQGH6oVP_JDPpERU_Hcb XCoe8dqUcsI7vrkjNz4tHg6RveRIBoCv7MQAvD_BwE
rfuerst911sc 03-07-2021 03:26 PM
I don't think a trencher will give me the width of cut I want . While it doesn't HAVE to be 16" wide that's what I have dug by hand so want to stay approx. the same . The lot slopes towards this trench , so when it pours a good amount of water volume is created .
wdfifteen 03-07-2021 03:33 PM
There is a small backhoe commonly available with a 16” hoe that will fit a small trailer. It’s called a Terramite and it’s about the size of a sub compact tractor. It’s just what you need. A mini excavator would work too.
TimT 03-07-2021 03:50 PM
Check local tool rental places, find a Bobcat with a backhoe attachment..
Or do a few passes with a ditch-witch to loosen the soil and excavate by hand
cabmandone 03-07-2021 04:07 PM
Tiny mini ex like a Bobcat E10 or Kubota K008
908/930 03-07-2021 04:14 PM
Check your local ads for an operator that has the equipment, mini excavator or whatever, unless you already know how to use one. Space restrictions? What will you damage if you make a mistake, make sure they are insured.
URY914 03-07-2021 04:48 PM
Get the largest machine that will fit into the space. Always better to have a machine with enough ass to take care of the job. A machine too small is frustrating when it doesn't get the job done.
Alan A 03-07-2021 04:54 PM
I’m lazy. Since you are looking at maybe $500 for both for a half day I’d rent a trencher and a backhoe. Two cuts with the trencher to establish the borders and then backhoe to scoop out and refill. Be done in no time and it won’t be a mess.
If you had more space I’d say just backhoe, but if it’s tight then define the edges.
Nostril Cheese 03-07-2021 05:04 PM
This is what children are for. At least my summer vacations were spent digging footings.
dad911 03-07-2021 05:21 PM
Borderline job, finding a contractor to do the digging and filling with stone, vs renting.
Home depot gets $300/day for a small kubota tractor with a backhoe attachment. That's probably the smallest machine I'd use.
If you're not familiar with running a backhoe, there's a learning curve. My neighbor put one on it's side, and they had to bring out a bigger machine to right it.
Zeke 03-07-2021 05:26 PM
I'd rent a couple of men. Other than that, I'd check with the local ads as suggested and tell the person with the equipment you are not on a tight schedule and you have cash. If he is well enough equipped, he will bring the gravel with him.
2 birds — one stone.
1990C4S 03-07-2021 06:37 PM
Compare Milt's cost to a daily backhoe rental. Assume a real laborer is as fast as you...how long did you take to go 40'?
Baz 03-07-2021 06:45 PM
I hired a friend of mine and he had a narrow bucket.........
http://forums.pelicanparts.com/uploa...1615171327.JPG
His price for this job was only $250 but I ended up tipping him a $100 because I kept him there for 2 hours (total - an hour over what it would have taken) doing a couple other things.
You could rent a mini-excavator - worth calling for pricing - but having someone show up with their own machine - do the job - then leave - is a nice way to go as well.
Baz 03-07-2021 06:49 PM
http://forums.pelicanparts.com/uploa...1615171716.JPG
Esel Mann 03-07-2021 06:53 PM
check your local harbor freight for:https://www.harborfreight.com/40v-lithium-ion-cordless-16-in-brushless-chainsaw-tool-only-56938.html?_br_psugg_q=chain+saw
make sure they have a coupla xtra so you can do the exchange shuffle. be sure to wreck the last one so the cost is just gas to/fro the store. for your back, a four pack of st. bernardus. that'll get you easily another 80' with no feel, no swaet.
rfuerst911sc 03-08-2021 03:11 AM
A lot of good advice . I am concerned about learning curve vs possible damage . Finding someone with the equipment and experience with the equipment may be the best choice . Or hire one or two day laborers and go at it the old fashioned way . Thanks guys for the sanity check . SmileWavy
