rfuerst911sc's Avatar
Need to rent a digging tool - what to get ?
So I have hand dug with pick and shovel a drainage trench , so far about 40 feet. It is approx. 16" wide and about the same depth . But my back is waving the white flag 😩 and I have about 60' more to go .
Is a mini back hoe the proper tool ? I need it to be as small as possible due to space restrictions . I am running plastic drain pipes for gutters to drain into AND use the trench for rain runoff . Will be filled with gravel . Any advice on what tool is best is appreciated as I have never done this before .......... and hopefully never will again 😁
Old 03-07-2021, 02:49 PM
Rent a trencher
Old 03-07-2021, 02:57 PM
^^^ Good choice. Also if you are going to use the trench for drainage, get some fabric (landscaping ?) from H.D. or wherever and liine the trench with it, lay your drain pipe and fill the fabric lined trench with your gravel. Overlay the fabric over the top of the trench & spread a couple of inches of gravel on top.
Marv Evans
'69 911E
Old 03-07-2021, 03:06 PM
Parrothead member
VINMAN's Avatar
If it needs to be 16" wide, I'd go with the mini excavator. A trencher/ ditch witch is only a few inches wide.
Vinny
Old 03-07-2021, 03:18 PM
That thing above or a small chipping hammer. Don't rent the big and heavy one jack hammer, because moving that damn thing all day will hurt but the added weight is nice as it cuts into the soil. Rent a spade or shovel bit with it. Use a narrow shovel to scope the soil out. Easy and the 60' will be done one afternoon. Its more work to shovel the dirt out then it is to dig. No more fooking pick unless you want to lose weight and get 6 pack?
https://www.tools-plus.com/bosch-rh1255vc.html?gclid=CjwKCAiAkJKCBhAyEiwAKQBCkopr9N ZJZ8LmXvfoS4ZvRW9Ci3DVaGfY_XTkM06XDEJM160KI9f6yRoC hJUQAvD_BwE
Here's the bit, get the longest one possible.
https://www.harborfreight.com/4-12-in-sds-max-type-clay-spade-bit-60414.html?cid=paid_google|||60414&utm_source=google&utm_medium=cpc&utm_campaign=&utm_content=&gclid=CjwKCAiAkJKCBhAyEiwAKQBCkhQM3uQGH6oVP_JDPpER U_HcbXCoe8dqUcsI7vrkjNz4tHg6RveRIBoCv7MQAvD_BwE
Old 03-07-2021, 03:23 PM
I don't think a trencher will give me the width of cut I want . While it doesn't HAVE to be 16" wide that's what I have dug by hand so want to stay approx. the same . The lot slopes towards this trench , so when it pours a good amount of water volume is created .
Old 03-07-2021, 03:26 PM
wdfifteen's Avatar
There is a small backhoe commonly available with a 16” hoe that will fit a small trailer. It’s called a Terramite and it’s about the size of a sub compact tractor. It’s just what you need. A mini excavator would work too.
Old 03-07-2021, 03:33 PM
Navin Johnson
TimT's Avatar
Check local tool rental places, find a Bobcat with a backhoe attachment..
Or do a few passes with a ditch-witch to loosen the soil and excavate by hand
'69 911 GT-5
'75 914 GT-3
and others
Old 03-07-2021, 03:50 PM
Brew Master
cabmandone's Avatar
Tiny mini ex like a Bobcat E10 or Kubota K008
Nick
Old 03-07-2021, 04:07 PM
908/930's Avatar
Check your local ads for an operator that has the equipment, mini excavator or whatever, unless you already know how to use one. Space restrictions? What will you damage if you make a mistake, make sure they are insured.
Old 03-07-2021, 04:14 PM
Get the largest machine that will fit into the space. Always better to have a machine with enough ass to take care of the job. A machine too small is frustrating when it doesn't get the job done.
Old 03-07-2021, 04:48 PM
I’m lazy. Since you are looking at maybe $500 for both for a half day I’d rent a trencher and a backhoe. Two cuts with the trencher to establish the borders and then backhoe to scoop out and refill. Be done in no time and it won’t be a mess.
If you had more space I’d say just backhoe, but if it’s tight then define the edges.
Old 03-07-2021, 04:54 PM
Hell Belcho
Nostril Cheese's Avatar
This is what children are for. At least my summer vacations were spent digging footings.
Old 03-07-2021, 05:04 PM
Platinum Member
dad911's Avatar
Borderline job, finding a contractor to do the digging and filling with stone, vs renting.
Home depot gets $300/day for a small kubota tractor with a backhoe attachment. That's probably the smallest machine I'd use.
If you're not familiar with running a backhoe, there's a learning curve. My neighbor put one on it's side, and they had to bring out a bigger machine to right it.
Old 03-07-2021, 05:21 PM
Zeke's Avatar
I'd rent a couple of men. Other than that, I'd check with the local ads as suggested and tell the person with the equipment you are not on a tight schedule and you have cash. If he is well enough equipped, he will bring the gravel with him.
2 birds — one stone.
Old 03-07-2021, 05:26 PM
Compare Milt's cost to a daily backhoe rental. Assume a real laborer is as fast as you...how long did you take to go 40'?
Old 03-07-2021, 06:37 PM
I hired a friend of mine and he had a narrow bucket.........
His price for this job was only $250 but I ended up tipping him a $100 because I kept him there for 2 hours (total - an hour over what it would have taken) doing a couple other things.
You could rent a mini-excavator - worth calling for pricing - but having someone show up with their own machine - do the job - then leave - is a nice way to go as well.
Old 03-07-2021, 06:45 PM
Old 03-07-2021, 06:49 PM
Whoopsies I was banned!!!
Esel Mann's Avatar
check your local harbor freight for:https://www.harborfreight.com/40v-lithium-ion-cordless-16-in-brushless-chainsaw-tool-only-56938.html?_br_psugg_q=chain+saw
make sure they have a coupla xtra so you can do the exchange shuffle. be sure to wreck the last one so the cost is just gas to/fro the store. for your back, a four pack of st. bernardus. that'll get you easily another 80' with no feel, no swaet.
Old 03-07-2021, 06:53 PM
A lot of good advice . I am concerned about learning curve vs possible damage . Finding someone with the equipment and experience with the equipment may be the best choice . Or hire one or two day laborers and go at it the old fashioned way . Thanks guys for the sanity check .
Old 03-08-2021, 03:11 AM
