-   -   Protection using iso-cyanates. (http://forums.pelicanparts.com/off-topic-discussions/1091908-protection-using-iso-cyanates.html)
Bill Douglas 04-25-2021 01:14 PM
I'm an occasional painter - garage style. I've done a few day classes, and painted a few panels.
But I'd like to use paints with hardeners, iso-cyanates in other words. And epoxy primers. I can paint outdoors so I don't need absolute protection.
What do you guys use or think of as being an acceptable minimum for an air feed respirator setup. I had been considering a second hand 3M Dustmaster and having the box upwind (or outside of the garage) and a longer air tube.
greglepore 04-25-2021 02:39 PM
I like that idea. For occasional use, it'd probably be fine. I wouldn't clear an entire car with that setup, but for limited exposure etc you'd probably be ok. I'd mount the intake as high up as possible. I don't know how powerful the fan is, might have to upgrade to a higher cfm unit if the hose run gets long.
TimT 04-25-2021 02:42 PM
That is probably fine as long as you use the correct cartridge.
Also wear a Tyvek suit nd cover as much of your skin as possible.. isocyanates can penetrate your skin..
Bill Douglas 04-26-2021 05:36 PM
Thanks Greg, thanks Tim.
greglepore 04-26-2021 06:44 PM
Second the reco for cheap tyvek suits. Disposable, local auto paint supplier has them.
Bill Douglas 04-26-2021 07:11 PM
Will do, thanks.
