My other ride is a C-130J
RNajarian's Avatar
Best way to clean a ratchet (drive wrench)
I’ve got a few WW2 vintage Plomb drive wrenches (ratchets.) They are in good working condition but I would like to service them.
Any recommendations on how to clean the mechanism and any oiling/grease suggestions?
Here are a couple of photos. I’ve also got several 1/2 size wrenches.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 05-08-2021, 10:20 PM
a.k.a. G-man
Geronimo '74's Avatar
Soaking it in wd-40 should get some crud out of the mechanism.
Old 05-08-2021, 11:09 PM
Hell Belcho
Nostril Cheese's Avatar
Remove the screw, cover, springs and ratchet mechanism. Clean out old grease with solvent (I usually use brake cleaner). Re-fit internal components and grease them up.
There's really not much inside them, easy to clean and figure out.
Old 05-08-2021, 11:37 PM
Hell Belcho
Here you go.. tons of videos on you tube as well, restoration.. mirror finish.. etc...
Old 05-08-2021, 11:46 PM
Team California
speeder's Avatar
Good advice so far, I'd maybe use paint thinner/mineral spirits to clean innards if you can still get it or have some around. A small amount of silicone grease or any light grease on the mechanism will keep it running smoothly.
Denis
Trump uses an autopen and votes by mail, in case anyone wonders.
Old 05-08-2021, 11:49 PM
RNajarian's Avatar
Thanks for the advice guys. One more question. . .
I’ve got a 1952 1/2” drive wrench missing one of the two screws for the front plate. Any idea where to get a new one? I’m thinking maybe a rebuild kit, but I only need one screw.
Old 05-09-2021, 04:44 AM
Hell Belcho
The screw should be common enough to find at a Lowe's/Home Depot, etc.. Just take it and match it up on one of those size and pitch finders in the nuts/bolts aisle.
Old 05-09-2021, 05:25 AM
Banned
Tobra's Avatar
Tale the screw you have to the hardware store and ask the oldest guy working there where to find one
I have a few of these from my grandfather. The innards are easy - just remove the screw and clean/regrease as stated above. I just soaked a rag with WD-40 and used that to scrub everything external.
Old 05-09-2021, 05:54 AM
Platinum Member
dad911's Avatar
Post a pic. Any way to measure the length and diameter? Do you have a caliper?
Otherwise bring the one you have to a hardware store, and try to match it up.
The truth is that while those on the left - particularly the far left - claim to be tolerant and welcoming of diversity, in reality many are quite intolerant of anyone not embracing their radical views. - Charlie Kirk
Old 05-09-2021, 06:56 AM
Model Citizen
herr_oberst's Avatar
If you have a hardware store in your area with wood floors and a potbellied stove where a few old jaspers sit around on saturday morning drinking coffee and swapping lies, take the whole ratchet there and ask if they have the proper fastener. You will find success.
Old 05-09-2021, 07:50 AM
RNajarian's Avatar
Replacing it is literally a turn of the wrist. . . finding the screw is a different story.
Old 05-09-2021, 09:54 AM
Registered ConfUser
Oh...and don’t forget to watch for that spring the takes flight and rolls under the hot water tank.
Mike
Old 05-09-2021, 12:31 PM
Hell Belcho
A good hardware store should have that. Look for cap head screws
Old 05-09-2021, 06:44 PM
Bland
unclebilly's Avatar
Get your snap on guy to replace the screw and the ratchet inerds.
Old 05-09-2021, 06:47 PM
Bland
unclebilly's Avatar
I have a couple of similar old snap on ratchets. One I actually bought new about 25 years ago.
Old 05-09-2021, 06:54 PM
A930Rocket's Avatar
I have one just like yours, but I never use it. I’ll have to take some pictures.
Old 05-09-2021, 06:58 PM
+2 on chasing the spring under the water heater. That's if you're lucky & know where it went. The problem is getting the spring in the hole, followed by the ball bearing, and holding it down while you insert the ratchet mechanism. Added 'degree of difficulty' points for accomplishing all this with fresh grease on all the tiny moving parts. Good news is you'll never have to do it again in your lifetime.
Old 05-09-2021, 10:31 PM
Model Citizen
Old 05-13-2021, 06:44 PM
I was going to say have a machinist make one, but I didn't want to sound crazy.
My impact Snap-On has a little grease fitting. It's pretty trick. I use a very tiny grease gun and that works just like using a zerk fitting.
Old 05-13-2021, 07:41 PM
