Anyone built a guitar from a kit?
I've ordered a Fretwire Telecaster kit. I've always wanted to try and build one and am open to any suggestions or experiences you might want to share.
1982 SC
Old 05-20-2021, 10:02 PM
Good luck..
Slodave build one years ago..
simply amazing..
he has done shift knobs and boards for Singer...
Rika
Old 05-21-2021, 06:51 AM
Rick Lee's Avatar
I've cobbled lots of Partscasters together out of stuff I had laying around. But I've never installed new frets on a new neck. I would think it's a false economy to do it that way unless you end up totally in love with the guitar and never want to sell it. I have a Musikraft neck on order now. It will run me $450 by the time I get it and DIY the oiling process. But it's exactly what I want and it's going on a Partscaster I otherwise love except for the neck I want replaced.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 05-21-2021, 07:05 AM
Slodave didn't build his from much of a kit.
Brent
Old 05-21-2021, 08:08 AM
Rick Lee's Avatar
I got to fondle Slodave's LP clone build at Hugh's house a few years ago. It was as good as they come. BUT it was a major project from scratch, and would not hold anything close to the value of a real LP.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 05-21-2021, 08:10 AM
That project was a labor of love and craftsmanship.
Brent
Old 05-21-2021, 08:15 AM
Senior Member
Superman's Avatar
Guys build guitars from parts all the time. Like Rick, I would recommend starting with a neck that already has frets.
Mocha 1978 911SC. "Coco"
Old 05-21-2021, 08:46 AM
Jeff Alton's Avatar
I Have a kit (strat style) I bought from an outfit is Australia. Pittbull Guitars. I have had it for a while. Hardware looks good (I checked a lot of the option boxes lol). However, I have no spare time to build it, will likely get on it after the summer. I will send the body out to get painted (viper green) as I will never have time to get that perfect.
We have 16 guitars between my son and I so not highly motivated to put off other projects to get this put together....
Looking forward to the day it is done. Even if it sucks to play, It will look good on the wall
Cheers
www.turn3autosport.com
Old 05-21-2021, 08:23 PM
Bill Douglas's Avatar
It's a shame we don't live closer. I'd love to paint or clear coat it for you. I did some furniture with automotive clear coat and it looks great.
Old 05-21-2021, 10:17 PM
LWJ LWJ is online now
I have built up several using a complete neck.
No big deal.
If you have to instal the frets and level them? I would make a jig with a drill press to press the frets in uniformly.
Finishing is the trick. Reranch has a whole bunch of cool colors in lacquer.
Old 05-22-2021, 07:12 AM
maybe have it Plek after it's done..
https://www.sweetwater.com/insync/what-is-plek/
Rika
Old 05-22-2021, 08:11 AM
Thanks for mentioning Reranch. I had not heard of them. I'm going to start with the body. Filler, sanding, filler sanding then prime, paint clear coat, wet sand polish.
Sound about right?
I'm not attempting to do anything like Slodave's build. I don't have anywhere near the skills
1982 SC
Old 05-22-2021, 09:55 AM
ckissick's Avatar
I've built 5 acoustic guitars from scratch; no kit. And I've not built an electric guitar. As the plek machine concept illustrates, getting the action correct is the most critical thing. When building an acoustic from scratch, you measure 100 times and glue once.
With a kit, the fit between the neck and the body should be spot on. I could see a cheap kit getting this wrong. I think the kit you have has the frets already installed. But they probably have to be filed properly. Anyway, you should pay most attention to the fit of the neck to the body. At least it's bolted on and can easily be removed to adjust the fit. When you glue the neck onto an acoustic body, put the strings on, file the frets, adjust the stress rod, and then find that the action is off, that sucks.
Charlie
1966 912 Polo Red
1950 VW Bug
1983 VW Westfalia; 1989 VW Syncro Tristar Doka
Old 05-22-2021, 01:09 PM
ASD ASD is offline
ASD's Avatar
just my 2 cenrs, but there are a number of low priced well built teles out there now
1999 Carrera2 tip arena red
2000 Boxster S tip...arena red ....black
1981 911sc targa...grey mkt.import...Rosewood
1978 911SC, guards red sunroof delete .much missed
73 914 2.0 found in a bunch of cardboard boxes, and brought back from the dead.
Old 10-27-2021, 01:29 PM
weekend wOrrier
Cool thing about kits, is-
There are a lot of options out there. Find out how deep you want to jump in.
And jump.
I use a drill press to press in frets with a stewart Mcdonald fret press.
Don't want to bother?- start with the frets already installed.
No right or wrong. Pick your pleasure.
Setup and action is where you want to spend your time (on any guitar).
Good luck.
Old 10-27-2021, 01:47 PM
Control Group
Tobra's Avatar
My brother built a guitar and some effects pedals many years ago
Old 10-27-2021, 03:20 PM
mechanic by night
i've built three. All three from parts. The thought of fretting a neck...no thanks. I aint that dedicated.
76 911 "The Blond B_ch"
(what the wife calls it)
09 Mazda 3
06 subaru legacy spec B
91 track miata
Old 10-28-2021, 02:39 AM
Finished it. I still need to do a proper set up on the neck
1982 SC
Old 10-28-2021, 09:51 AM
ASD ASD is offline
ASD's Avatar
Sweet play on!
Sent from my SM-G991U1 using Tapatalk
Old 10-28-2021, 09:57 AM
John Rogers's Avatar
I put together on of the semi-hollow body guitar kits from a company named "Bad Cat" which makes their kits in China. The fit of the neck was great, aligned just fine and only had to tweak the neck very slightly to take out some dip in the middle. It came with their own humbucker pickups that were already soldered together and sounded okay. I installed a pair of Seymour Duncan "Pearly Gates" pickups with 500k pots that could split the coils and also installed a 5 position switch. It can sound like ZZ Top or Eric Clapton if I pull the knobs up. I stained the body with a sun burst color scheme and 10 coats of clear lacquer and lots of sanding!
John
Old 10-28-2021, 11:48 AM
