Battery on/off switch.
Hi Guys,
I have a battery switch like this on my car for a long time, and it works fine. Today, looking at the item online and found that it is rated 500A. Our car is having 850 cracking amp battery. Does that mean if I have problem starting and keep it there cranking for a while, or if I start, turn off, start again, turn off and restart again several times, the switch will be hot and might be melted? lol. The design doesn't look that bad at all. You guys agree? Thanks. https://i.ebayimg.com/images/g/i8wAAOSw~KNgGgth/s-l1600.jpg
Fat butt 911, 1987 |
What amps does the starter pull when cranking?
Sold: 1989 3.2 coupe, 112k miles |
Rule of thumb per the internet... 1 amp per cubic inch.
umm... I dont know. Anyone knows?
Sorry I accidentally have same question in 2 diff places.
500 amps is more than enough - I think you are good.
I believe typical amperage draw from a starter during a start isn't any higher than something like 250A, so that's fine.
'80 SC Targa Avondale, Chicago, IL |
Hell Belcho
if this a 87 911, you're fine. Its not going to draw over 500amps starting
Saved by the buoyancy of citrus. |
Information Junky
a must read on these things: https://forums.pelicanparts.com/porsche-911-technical-forum/619776-green-knob-battery-switch-short.html
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee. ![]() |
The battery disconnect in Post #1 is OK, just be sure the bolts are tight.
There are better ones though. I use a military-grade battery clamp on my forklift. And tractor. It requires that you crimp lugs onto the cables, sort of like in a building. They key is to make sure all connections are tight, or you can have problems. |
Thread Tools | |
Rate This Thread | |
