carpentry question
I have a 8X12 ft wood utility shed with a door opening of 60 inches (pictured below)
I need to get a 66 inch door opening. Is there any way to refab the door opening?...or am I sol? The second pic shows how the hinges are attached. (door height needs to remain the same.) ![]()
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Where there's a will - there's a way.
You'll have to beef up the structure when you move each side of the door frame studs out the 3". Maybe a double layer of the plywood truss/reinforcement plate.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
I'd also suggest doubling up the header over the door - perhaps adding another layer to overlap the added plywood plates on each side.
Also - add the extra 3" door width to the non-hinge side of each door - assuming you won't be building new doors from scratch.
So you are saying...remove the frame studs...cut the opening wider and re-install the studs (after cutting them shorter)
Then put new wider doors on? I'm trying to picture the plate when the jamb is moved over three inches.
Still Doin Time
So I need ask - why does the opening need to be 6" wider?
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Ok....your last post came after I posted above.
You're saying that I could just extend each doors width...instead of scrapping them? You can prob tell by my questions that I'm not a builder!
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI Last edited by stevej37; 05-27-2021 at 11:25 AM.. |
The total width of the deck is 60" I'm figuring a min of 3" each side to clear.
Possibly, use the same doors, but add a board to the edge of one of them that is just slightly wider than the gap between them. Then it will look like 2 doors with a strip of wood down the center, but the strip of wood will be part of one of the doors.
![]() I think this will still look good, and will be easier than trying to alter both doors.
I assume there's no discharge chute to worry about.
^^^ Yes..that would be a lot easier than building two new doors.
And it would be barely noticeable. Even though the building is almost 20 years old...the wood is in excellent shape yet.
The chute will not be needed..it will come off.
Vaccinated and Boosted
Maybe consider a 54" deck on the new JD?
Or just go really fast into the shed a couple of times, that will be all it takes!
2013 911 Turbo S 2025 Lexus TX350, 2024 Honda CRV Hybrid 1930 Cadillac V8, 1991 Ford F250, 2023 Chevy Colorado And some garage space.... |
That's what it has...a 54" deck. The brochure says "Min storage width (deflector up) 59.4 inches." (I can't get by with .3 inch clearance on each side!) I thought about just enlarging the bottom foot of the doorway...lol
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI Last edited by stevej37; 05-27-2021 at 11:47 AM.. |
That was my thought. I've seen a similar setup in double doors in furniture or maybe closets or something.
I'm pretty sure the discharge chute on the deck of my zero turn sticks out even when it's up (although probably not by 6"). I assume it's a 54" cut, and therefore the inside of the deck is probably something like 54.5 or 55" and then there's probably a lip on the outside of the deck that sticks out a bit or maybe double layers. You may, before you make modifications, want to go to a store with the mower and take a measuring tape and helper when you go.
^^^ Good idea. I'll prob do that. Would save a lot of trouble if it would fit.
Yes, it's a 54"
Two "doggy door" style flaps for the deck?
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
Realizing now you are only concerned about the deck - move the bottom hinges up about 4" and then just cut out slots on each side of the frame and doors like in the picture below!
Here's a pic of it.
AWS with their new deep accel deck.
[QUOTE=MBAtarga;11345176]Realizing now you are only concerned about the deck - move the bottom hinges up about 4" and then just cut out slots on each side of the frame and doors like in the picture below!
![]() The ground squirrels would love that!
