Easiest oil change car ever!....for me.
The Honda Fit was showing 20% of oil life remaining today and it's at 10,000 miles since the last change. (a little early...but today I had the time)
Pull it into the garage..slide a 4X4ft piece of cardboard and drain pan under from the front. With a 15mm wrench and a new filter...it's only a matter of about 5 minutes and the oil is drained and new filter installed. (no lifting or ramps needed) Open the hood and pour the whole 5qt jug of Valvoline Syn in and it's done. Most of the time, I don't even check the dipstick when done...it works out perfect. 10 minutes or less...every time. The sad part is...it might be close to the last change...next one will come at over 250,000 miles.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI Last edited by stevej37; 06-08-2021 at 11:01 AM.. |
What's the fun in that? I mean, aren't oil & filter changes supposed to be difficult and messy?
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
^^^ I didn't count it as part of the time...but the transfer of oil (from the drain pan) to a disposal container is the worst part. I have a few 2.5 gal jugs I use...but it's still messy.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
With 20% oil life left (according to the minder), I could have prob driven it to 12,000 miles between changes.
You do not have permissi
yes but did you drop the oil drain pan at least once?
Meanwhile other things are still happening. |
^^^ Never with the Fit....but I have lost control of the pan with the 10qts from the 911 and dumped about a qt on the floor! Such fun to clean that up.
Corolla is similarly easy.
Around my place I have oil change day. All vehicles get oil changes whether they need it or not or not. If I'm going to have spilt oil on my arms and clothes I might as well do the lot. |
^^^ That's a good idea. Saves getting everything ready at any day of the week.
Always a good feeling after 'getting it done' Almost feels like the car runs/drives better.
![]() I have a drain pan similar to this that a customer left at our garage door for disposal of used oil and never came back to claim it…so I kept it. No transfer mess. Carry it to the local recycle center here and pour it straight into their big vat. No fuss no muss…spray it off with a little brake clean and wipe with a paper towel. |
^^^ What's the capacity? I can't quite read it on the pic.
You are clearly missing out on the joy of having to remove 3 different splash shields with 46 fasteners of 3 different types and sizes. Then , no dipstick, so it takes you a ride around the block and 10 minutes of idle time to check the oil level.
Honda engineers are weak.
No left turn un stoned |
I love missing out on stuff like that!
On my old Tiguan you could just extract the oil through the dipstick tube and the filter was at the top of the engine. Once it's in the extractor you have a sealed can full of oil that can be taken to the disposal site. I don't think I spilled a drop of oil the whole time I owned that car .
Still didn't make up for having to do the water pump every 45k miles. |
hondas have definitely been the easiest cars to work on that I have owned
my wife had an 07 accord at one point, it was the 4 cyl version but the engine bay is sized for 6 cyl upmodel as well. Hardly had to do any work on it, but when It was comically easy.
84 930 18 Cayman GTS |
^^^ Same here
![]() My Prelude is equally easy for oil changes.
Remember the old days when you just let the oil run onto the ground and you kicked the dirt over it to cover the spot?
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
I remember the old days when my 66 Chevelle had a canister that held the oil filter.
If I didn't get the gasket in there correctly....oil was a drippin.
My other ride is a C-130J
Do these drain pans came manufactured in metal. I have one with a screw on top to close the container. The entire product is flimsy. I would prefer a more robust material
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A |
No...they spin the same way as the toilets.....the correct way
