Run smooth, run fast
Heel n Toe's Avatar
Another refrigerator puzzler
A few months ago I thought about the fact it had been a long time since I cleaned the dust off the coils (or whatever they're called) in the area below our side-by-side fridge. So I pulled that cover off and it was solid dust and dog hair.
Got it all cleaned out, then started checking temps inside fridge and freezer. After a bit of adjusting the knobs inside the fridge and checking, the temps went to where they need to be and stayed there.
Lately, we noticed that the face of that divider between the two compartments is fairly warm... along with the rubber seals that close up against it. There's even a "warm rubber" smell at times.
All temps are spot on. Is this a concern or is that normal? Fridge (GE) is probably about 20 years old.
- John
Old 07-07-2021, 11:21 PM
My other ride is a C-130J
RNajarian's Avatar
The refrigerator wouldn’t happen to be a GE Monogram? My 20 year old Monogram (built in 42 inch) would get warm at the center divider too, but we didn’t get the rubber smell.
After 20 years the Freezer couldn’t keep ice cream frozen. Temperatures fluctuated from 14 degrees F to 25F. The rubber seal probably needed to be replaced after 2 decades. They would get warm too but no smell.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 07-08-2021, 12:15 AM
wdfifteen's Avatar
Normal. There are heaters in the walls of the fridge where the seals contact the case to keep condensation down. Without the heaters leakage of cool air past the seals will allow warm, moist air in the room to condense on the exterior of the 'fridge near the seals. Some refrigerators have a switch that allow you to turn the case heaters off.
Old 07-08-2021, 05:04 AM
HobieMarty's Avatar
Here's mine, Kenmore made in October of 2000!!! I've recently changed the defrost thermostat and added just a tiny bit of freon. The freezer maintains -10°F. This is a fridge we have in our laundry room for extra stuff and beer!!!
Wonka
Old 07-08-2021, 07:00 AM
HobieMarty's Avatar
Oops forgot the pic!!!
Wonka
Old 07-08-2021, 07:03 AM
HobieMarty's Avatar
If you still have the fridge, you can add a little freon to it pretty easily.
Wonka
Old 07-08-2021, 07:08 AM
HobieMarty's Avatar
https://youtu.be/jd8KZNnhTEs
This tell you how to add freon to a fridge. You use a piercing valve. If you do this, make sure the valve you order has the little gasket already fitted on the valve. I ordered one and it had a gasket that you had to put on yourself and I didn't like that so I found the exact one that is in this video.
Wonka
Old 07-08-2021, 07:14 AM
wdfifteen's Avatar
There is no need to add freon or do anything at all. It is perfectly normal for those areas to feel warm. They are supposed to be warm.
Old 07-08-2021, 10:55 AM
Control Group
Tobra's Avatar
I think the thermostat went out on my fridge. It is 18 years old, so maybe it is just tired
Old 07-08-2021, 12:52 PM
HobieMarty's Avatar
Suggested adding freon because of the extreme temperature fluctuation.
Wonka
Old 07-08-2021, 04:45 PM
HobieMarty's Avatar
Side by side? Take everything out of the freezer and remove the inside back panel. If you see ice build up on the coils then it is freezing up. Just like if your home a/c freezes up, the system cannot move the cool air through the coils, therefore, it won't properly cool. If there is ice on the coils, turn the fridge off, get a blow dryer, not a heat gun, and melt the ice. There will be a small round part with 2 wires coming out of it on top of the coils, this is the defrost thermostat. If it looks like it has split open then it has failed and needs to be replaced. They cost around 15 bucks. Hope this helps.
Wonka
Old 07-08-2021, 04:54 PM
Control Group
Tobra's Avatar
The freezer is cold, the fridge is not cold enough. Coils on back not that warm, accumulator tank, or whatever it is called, is quite warm, maybe compressor?
Old 07-08-2021, 06:11 PM
HobieMarty's Avatar
The fridge gets the coldness from the freezer so it sounds to me like there is something blocking airflow somewhere. Some refrigerators have doors that open and close depending on the needs/temps of the fridge.
Wonka
Old 07-08-2021, 06:27 PM
HobieMarty's Avatar
Found a few reasons as to what would cause the problem.
Wonka
Old 07-08-2021, 06:31 PM
Heel n Toe's Avatar
Thanks for all the input. I did consider that it might be normal for that area to be warm, but I wondered why we hadn't noticed it until now because I figure we touch the seals fairly often when opening the doors.
The PP Brain Trust comes through again!
- John
Old 07-09-2021, 12:32 AM
