Senior Member
Strippers
I think you will agree that not all strippers are equal. This thread is about the difference between good strippers and bad ones.
The woman who, thankfully, runs my house and makes me happy is on a furniture refinishing vector. He is sanding and painting some wood chairs for our veranda in delightful colors using brightly colored latex paint and clear polyurethane, and the results are expected to be very pleasing. She tried stripping them using a very popular stripper which did little to strip the chairs and left an orange residue behind. She abandoned the stripping idea and is just sanding and painting, which likely will work great. Now she is talking about refinishing the crappy, cheap night stands in our bedroom and I am concerned for her sanity. These are dark-stained things which she hopes to re-stain. This, I think, means thoroughly stripping the existing finish. I am skeptical about stripping furniture that I think was previously stained, particularly using stripper which does not work but leaves orange residue. I think she should sand and paint them, but I wonder if stripping is a viable option. I can recall, years ago, using a stripper that worked. It was a clear jell (not orange) which did a great job of lifting and dissolving the paint which could then be easily scraped off. Am I dreaming, or was there such a thing? Is there such a thing as a really good stripper, and where can I find it / her?
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Years ago when we were working on our fixer-upper first home we spent forever removing paint from all the original 1920 woodwork. At that time the Jasco "Speedomatic" was hands down the way to go. Worked much better than regular Jasco which means it probably had horrendous ingredients. We also tried citrus-based strippers and nothing would come close to the Jasco. We joked that we knew it was working when a tiny splash would land on your arm above your gloves and immediately start burning through your skin. After giving plenty of time to air dry we never had issues putting new stain back on the wood.
I currently do restoration of vintage fiberglass things and the citrus strippers work great on those as they're not nearly as aggressive. |
Brew Master
Nick |
I have to say, I’m really disappointed because of the subject title and the subject. 😂
Senior Member
Thanx, Hockey Fan. I will look for this product. Yes...it burns like Hell on your skin.
Is this the product you're thinking of? We used it to strip our kitchen table to refinish it.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
All I can add is get the surfaces really clean (clean of stripper) before adding top coats. Some can be very caustic.
A Man of Wealth and Taste
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
Seeing the title, I had great expectations of being able to contribute clear, concise and expert opinions on the subject matter.
Then, after reading the first three posts, I realized it wasn't the area of expertise I was familiar with. I got nothin'.
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
Model Citizen
Methylene has been outlawed for use in strippers. That's why the stuff 20 years ago used to work great and the current junk wouldn't take gum off the bottom of a shoe.
You might look into stripping services that dunk the wood in a big ol' tank of death.
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
Bland
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
Brew Master
Nick |
weekend wOrrier
Strippers need to strip fast. If they cause a rash, so be it.
I have found that lacquer thinner works as a stage II, before the stripper 'dries up'. Steel wool and tough fingers help. Thick gloves if you're a pussy. (I felt compelled to use that word).
I have also had good luck with heat plates, not the guns that blow air, just an element in a metal shroud. Use that t get 90% of the top coat, then strip, thinners, and sanding. Be careful. It's easy to burn the wood.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Brew Master
So you're saying we should put gloves on our cats if we're using that stuff?
Nick |
Platinum Member
![]() I used some stuff called 'Soy Gel' years ago to strip an outdoor patterned concrete sealer. Worked very well, yet didn't kill our landscaping. Probably went through 20 gallons on a 1000 sf patio and walks. Sprayed it on, covered with thin plastic so it wouldn't evaporate/dry up, and let it do it's thing. If you're not a fan of the "crappy, cheap night stands" I recommend the all natural way to remove the finish. Put them outside for 6 months, and let them weather. Good furniture might survive, and the finish will be trashed. Particle board not so much......
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
