My other ride is a C-130J
Any Lithium Battery Savants Here?
Quick Question: Is 0.17 volts a normal amount of discharge for a small 12v lithium battery during a 12 hour period?
Background I’m in the process of a complete dash makeover of my golf cart. Once completed I’ll post photos of the project. I’ve already installed a traditional speedometer, wired to a switched 12v accessory. I will be installing an outside temperature gauge and a marine radio, also wired to a switched 12v wire. Finally I have a 52mm (2 inch) VDO style analog clock I will be installing. It works great and keeps accurate time. I’ve decided to have a small 12v battery in the front trunk to power this accessory. The type used as backup batteries for security systems. I thought that on the first of every month when I check my water levels I can recharge the battery. This way I don’t have to deal with the cart’s 48 volt main battery pack. I hooked up my clock to one of these batteries and I noticed over a three day period maybe the battery lost 0.01 volts during this time. I decided to use a similar sized lithium battery for this purpose, obviously wanting to reap the benefits of lithium. The traditional sealed lead acid battery weighs 6 pounds and the lithium battery weighs one pound. I charged up the lithium battery and upon completion of that charge it registered 13.50 volts. I hooked up my battery and 12 hours later the battery registered 13.33 volts, a loss of 0.17 volts over a 12 hour period. Is this normal? Obviously I will monitor the set up over the next week or so but it seemed strange to lose 0.17 volts in such a short time, especially when the sealed lead acid battery seemed to lose none of its charge. Thanks for your thoughts. ![]() ![]() Here is a photo of the lithium battery ![]() Here is a photo of the traditional sealed lead acid battery
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A |
