LinkBack Thread Tools Rating: Thread Rating: 3 votes, 2.33 average.
Ctopher's Avatar
Originally Posted by Por_sha911 View Post
Just make sure you don't use the standard Simple Green - bad things happen to certain metals.
I use P21S Total Auto Wash. PH neutral citrus cleaner and safe to use.
That’s why I specifically said simple green aircraft because it is safe on aluminum.
Old 08-08-2021, 10:01 PM
Zeke's Avatar
Originally Posted by dan79brooklyn View Post
I’ve seen on YouTube car detailers using dry ice cleaning machines. They do an incredible job. Obviously they can’t be cheap. But it looks so satisfying to see the dirt just disappear.
https://youtu.be/fHy_JpRI4lw
DI is wonderful for cleaning almost anything from suede to granite.
I used to keep engine compartments squeaky clean but not so much anymore with all the sensors. If you local clean the electronics and waterproof them ahead of time, it's better. Kinda like owning an old Brit car with Lucas.
I used a degreaser followed by detergent and then a light spray, but concentrated in hard to reach areas.
BTW, the best old time waterproofing was spray can shellac. It can be washed off with alcohol if needed. Solvents like turpentine can wash off some older engine compartment paints. Old to me is <70's.
Old 08-09-2021, 06:45 AM
do you have your own dry ice cleaning machine?
Old 08-09-2021, 03:35 PM
A930Rocket's Avatar
I’ve never heard of simple green aircraft, but what’s in simple green that’s bad for what metals? I’ve not had any issues with it.
Edit: it’s great for cleaning greasy hands.
Edit 2: wow. It’s $27 vs $5 for 32 oz!
Old 08-09-2021, 05:41 PM
Ctopher's Avatar
https://simplegreen.com/industrial/products/extreme-aircraft-precision-cleaner/?locale=en
You can find it on Amazon. It’s the only thing I use now, don’t even buy the other stuff anymore. Beyond cleaning engine bays this also works great in a ultrasonic cleaner and since it’s not corrosive on aluminum you never have to worry about how long you let aluminum soak and having to worry about corroding and causing discoloration.
CTopher
Old 08-10-2021, 02:58 AM
