-   -   Compression check thoughts… (http://forums.pelicanparts.com/off-topic-discussions/1101684-compression-check-thoughts.html)
A930Rocket 09-06-2021 10:20 AM
I did a compression check on the 05 BMW 330ci today and wanted your thoughts.
1 and 6 look close, as does 2-5.
http://forums.pelicanparts.com/uploa...1630948835.jpg
Scott Douglas 09-06-2021 10:35 AM
Those numbers look pretty good to me.
How many miles on the engine?
A930Rocket 09-06-2021 10:39 AM
Originally Posted by scott douglas (Post 11449333)
those numbers look pretty good to me.
178k
Scott Douglas 09-06-2021 10:41 AM
Then they look damn good to me.
What are you worried about?
A930Rocket 09-06-2021 10:58 AM
With the ticking/tapping noise at part throttle over 2600 rpm, I’m just looking into the health of the engine.
I’m about to dig into replacing the lifters.
asphaltgambler 09-06-2021 01:45 PM
If you did a top engine clean with a BMW approved cleaner, those numbers will move closer together.....
greglepore 09-06-2021 02:35 PM
This
A930Rocket 09-06-2021 03:09 PM
That’ll have to wait until I reassemble it next weekend. I did run two quarts of ATF for a few mikes and some idling last weekend.
Edit: I probably should’ve gotten a new compression tester, as that one is at least 40 years old.
http://forums.pelicanparts.com/uploa...1630966103.jpg
wdfifteen 09-06-2021 06:05 PM
Those numbers at 178k? You’re showing off. :D:D
A930Rocket 09-06-2021 06:28 PM
What is the BMW approved cleaner?
jyl 09-07-2021 02:20 AM
I had a PPI on a BMW I-6 and noticed a similar pattern - cyl 1 and 6 similar and higher than cyl 2-5 which were consistent with each other.
Is that common with inline 6 engines or with BMW 6 cyl?
A930Rocket 09-07-2021 08:03 AM
I wish I could post a gif or video of the chain ramp that the tensioner presses on. It has a wobble, instead of only side to side movement Am I thinking right?
svandamme 09-07-2021 11:35 AM
real health : get leakdown test.
compression test looks good but only tells a basic story
