Compression check thoughts…
I did a compression check on the 05 BMW 330ci today and wanted your thoughts.
1 and 6 look close, as does 2-5. ![]() ![]() ![]() ![]() ![]() ![]()
Those numbers look pretty good to me.
How many miles on the engine?
Scott '78 SC mit Sportomatic - Sold |
Then they look damn good to me.
What are you worried about?
With the ticking/tapping noise at part throttle over 2600 rpm, I’m just looking into the health of the engine.
I’m about to dig into replacing the lifters. |
Still Doin Time
If you did a top engine clean with a BMW approved cleaner, those numbers will move closer together.....
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
This Sent from my iPhone using Tapatalk
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
Edit: I probably should’ve gotten a new compression tester, as that one is at least 40 years old.
Those numbers at 178k? You’re showing off.
I had a PPI on a BMW I-6 and noticed a similar pattern - cyl 1 and 6 similar and higher than cyl 2-5 which were consistent with each other.
Is that common with inline 6 engines or with BMW 6 cyl?
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
I wish I could post a gif or video of the chain ramp that the tensioner presses on. It has a wobble, instead of only side to side movement Am I thinking right?
Gon fix it with me hammer
real health : get leakdown test.
compression test looks good but only tells a basic story
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
