-   -   Induction VS Gas (http://forums.pelicanparts.com/off-topic-discussions/1101806-induction-vs-gas.html)
masraum 09-09-2021 01:07 PM
Originally Posted by masraum (Post 11453012)
THAT whole POST was IN caps. :D
I have a theory that is when it'll "fix" the problem for you.
BUT If YOU PUT ONE LETTER IN LOWER CASE, YOU'RE GOOD.
Zeke 09-09-2021 01:32 PM
Don't you have a bridge to fix somewhere?
1990C4S 09-10-2021 09:56 AM
He's IT, he has a computer to fix. Vash 'fixes' bridges. Or says he does.
If I want my stove clean all the time, I will but electric. To get the best stove, I would buy gas. The gas is batter but a pain in the sss to keep clean.
svandamme 09-10-2021 10:26 AM
induction is great.. the heat is INSTANT.
Way more then with gas , even if you have copper pots on gas, it's nothing compared to induction on steel because it's the pot itself that is the heating element.
There is only 1 thing I hate about induction, and that's the controls.
I want a turn dial and not stupid touch buttons that get all confused when there's some fluid involved.
But it's no where enough of a grip to want to pick gas over induction
One you go induction you never wanna go back
svandamme 09-10-2021 10:29 AM
Originally Posted by HardDrive (Post 11451066)
Not sure what kind of cooking class would lead one to prefer an electric stove....
You ever been in a commercial kitchen that uses electric? No. Gas is superior IMHO. We use a Viking, excellent.
modern kitchens installed for Gastronimical Chefs are increasingly induction.
Much better heat control
Doesn't heat up the kitchen itself as much as gas, so keeps the pots hot and the cooks cool.
MUCH easier to clean
It's safer in terms of fire risk
It's safer in terms of burn risks
<iframe width="1180" height="664" src="https://www.youtube.com/embed/7p6buePWKlI" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
svandamme 09-10-2021 10:34 AM
2 Michelin chef not far from where I live ..
defo a pro, and a professional kitchen.. he uses induction.
<iframe width="1180" height="664" src="https://www.youtube.com/embed/GODOOfObT5M" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
svandamme 09-10-2021 10:36 AM
3star Michelin kitchen.
I think the argument about "commercial kitchens" is dead in the water now.
<iframe width="1180" height="664" src="https://www.youtube.com/embed/TR-yXAacEyE" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
MikeSid 09-10-2021 12:33 PM
One question I've always had about induction is how does the pot handle stay cool? If I use a cast iron pan, I presume the handle is exactly as hot as the cooking surface. Do certain induction pans use non-ferrous metal in the handles? Or an insulating piece to isolate the magnetism away from the handle?
svandamme 09-10-2021 12:40 PM
Induction only works over the actual zone.
The handle is outside the induction zone, doesn't heat up by induction.
https://www.scienceabc.com/wp-conten...-Diagram-2.jpg
Handle warming up as such is no different from on a gas stove, probably even less because with induction there is no heat from the gas burner that just blows past the pan .. All heat is generated exactly and only where you want it : in the pan itself.
svandamme 09-10-2021 12:44 PM
note, it's also very limited in height. .it's not like your metal spoon will suddenly turn hot in your hand as you scoop up food out of the pot...
Obviously you should avoid holding a metal spoon in your hand and then holding it right over the induction zone.. that would be a bad idea
But then again, it would probably be even worse if you held it over lit gas burner.
I'm not going to try either to figure out which is worse
