-   -   Inhaled Battery Smoke (http://forums.pelicanparts.com/off-topic-discussions/1102659-inhaled-battery-smoke.html)
Racerbvd 09-20-2021 06:04 PM
What are the symptoms?
URY914 09-20-2021 06:05 PM
Posting pictures of yourself. ;)
Bill Douglas 09-20-2021 06:19 PM
So... What happened?
And are you OK?
William930t 09-20-2021 06:31 PM
from the EPA: Sulfuric acid is a highly corrosive chemical that is potentially explosive in concentrated form. It can cause severe skin burns, can irritate the nose and throat and cause difficulties breathing if inhaled, can burn the eyes and possibly cause blindness, and can burn holes in the stomach if swallowed. Hope you are ok.
Por_sha911 09-20-2021 06:41 PM
especially when they are ones posted before.
If anything is not "normal" then get to a doctor
Aurel 09-20-2021 06:54 PM
What battery? Assuming a lead acid battery…
What smoke? Was the battery overcharging or burning?
Assuming overcharging, there could be hydrogen, water, oxygen.
If it was overcharged for very long time, there could be H2S, which can be deadly, but since you are typing, you are most likely fine.
https://wwwn.cdc.gov/TSP/MMG/MMGDetails.aspx?mmgid=385&toxid=67
Racerbvd 09-20-2021 07:12 PM
From when my car burned last week, I think I breathed some in.http://forums.pelicanparts.com/uploa...1632190147.jpg
sc_rufctr 09-20-2021 07:23 PM
If you inhaled enough Battery Smoke to harm yourself you wouldn't be posting about it here.
Years ago I prepped a concrete floor with acid so I could lay ceramic tiles on top.
I used "pool acid" neat... (Hydrochloric Acid) - Nasty stuff but it got the job done.
The problem with acid is being trapped in a confined area. If you're out in the open you can get way from it.
EDIT: Just saw the photos... Thank **** you're OK. If in doubt go and see your doctor. Take care Mr Byron.
Aurel 09-20-2021 07:33 PM
Sorry about the car…Since the battery burned, I would be concerned about sulfuric acid fumes inhalation. But if that was the case, you would have felt irritation in your nose, throat, lungs very rapidly.
pmax 09-20-2021 08:12 PM
The car, ouch.
Unless you're standing there wafting in the fumes, hard to see how there would be serious injury. How's the face ?
craigster59 09-20-2021 09:29 PM
All those cigars and booze and you're worried about "battery smoke".
Take 2 shots of Pappy Van Winkle, smoke a Robusto and call me in the morning.
tabs 09-21-2021 12:30 AM
The red fumes from Nitric acid will cause pulmonary adema ..
dan79brooklyn 09-21-2021 12:36 AM
Dude :( You lost two 944s this year, I’m so sorry.
astrochex 09-21-2021 01:10 AM
The prior car was a 968.
So sorry Byron. Glad you got out of it ok.
Aurel 09-21-2021 03:13 AM
There is no nitric acid in lead acid batteries, chemistry genius.
porsche tech 09-21-2021 03:48 AM
Scary! Guess it wasn’t the recalled hose going to the fuel rail (as I said in the other post). Any idea why the battery fried? Glad you survived it!
Racerbvd 09-21-2021 05:13 AM
[QUOTE=porsche tech;11463225]Scary! Guess it wasn’t the recalled hose going to the fuel rail (as I said in the other post). Any idea why the battery fried? Glad you survived
The fuel line was only a few years old, everything under the hood was fresh, a SP1 buil engine. http://forums.pelicanparts.com/uploa...1632226129.jpg
Based on the sound I heard right before, I think this is the reason. http://forums.pelicanparts.com/uploa...1632226251.jpg
I was running back and forth grabbing stuff out of the car and have been having a lot more trouble breathing since
KFC911 09-21-2021 05:26 AM
Damn Byron... what happened... is there a thread about it?
sc_rufctr 09-21-2021 05:35 AM
Please go to the doctor.
astrochex 09-21-2021 05:59 AM
Originally Posted by sc_rufctr (Post 11463287)
please go to the doctor.
+1
