Platinum Member
Why is my mouse double clicking randomly?
Started about a week ago. I've swapped devices, changed the batteries, plugged into a different UBS port. Disabled Windows driver and installed logitech driver. nothing above worked.
Sometime a left click is a double click. Driving me crazy. It's bad enough that a click on the back arrow sometimes goes back multiple pages, but it's damn hard to edit a word document.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Platinum Member
?? it is actually a logitech 3 button track ball. Been using them for years, I don't think it's operator error. Swapped with a spare/new one, same results.
I'm guessing a windows update bug.?
Can you go into the control panel and adjust the properties of the mouse ? I only use laptops with touch pads but thats the way they work.
Information Junky
"Sometime a left click is a double click. "
likely a dirty switch. Clean or replace.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
canna change law physics
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
There were certain Logitech mouses that had this as a common failure mode.
This happened to me and I tried to fix it then ended up getting a new Logitech mouse. My new mouse (Performance MX) is good until the rechargeable battery dies - which seems much faster than advertised.
Sold: 1989 3.2 coupe, 112k miles |
Super Moderator
...but he said he tried a different device so that likely rules out the mouse hardware.
I wonder if their is an accessibility setting in Windows.. ..or maybe your “double click” speed is set so long that your previous click and the next one are registering as a double.
Platinum Member
No threats, no malware found.
Information Junky
I suppose that one could swap mouse buttons in software. Test that way. Flakey USB connection?
Platinum Member
Good point Island. Swapped buttons in software. will report back....
Information Junky
Yeah, w/ respect to my BTDT comment, this video (Below) is pretty much spot on --same mouse (x2) that had the same problem (x2) that I experienced. ...and fixed. (x2) And, being a gamer's mouse, those switches are more heavy duty than most. --yet still get dirty.
https://www.youtube.com/watch?v=kK7vwgZ7O28
Information Junky
Oh, one comment about that vid; he cleaned the switchs the hard way (for that mouse.) --he replaced the switches. (not needed)
the switches can be disassembled while on the board (PCB) and cleaned. Much easier w/o de-solder/solder.
Information Junky
Best played at 2x speed.
Platinum Member
Thank you.
Swapped a third corded one, problem seems to be gone. (Yes, I really like this track ball) Never thought two would be bad at same time......
Information Junky
I'm glad to help.
You may want to look at upgrading to the MX Ergo Advanced. It's rated at 10-million clicks compared to the 100k click guarantee of the M570. And is nicer in many other ways.
Platinum Member
Ordered upgrade.
Hope I don't like it too much, I'll have to buy 4 more....
Super Moderator
Information Junky
Would you like to do the math? -- https://pdfs.semanticscholar.org/e172/4ac1e589fcafc33784e219657ed3627982cd.pdf
Information Junky
Oh, and if the switch contacts are silver(plate) or copper the oxide layer will form even in a drawer. -tarnish, not so conductive.
Edit ...which in a wireless device is challenging for the minimal current used to save battery.
I bought 2 more, and those started to do the same thing within the following year of use. I called Logitech about it, and their customer service was great. I had 4 new mice delivered to my door within a week. Still using the first 2 replacements and all is good after 2+ years of use. |
