Beautiful tree.
Could some local kid be paid cash to do the picking up. |
They wanted to dry the skin out and harvest the nut. I told them "ok" and they spent an afternoon picking them up. Never seen them since! There are no kids that want to make money around here.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Exactly. I was wondering if there was a larger scale version of that that could be mounted to the front or back of the tractor.
FUSHIGI
No squirrels? Between acorns and walnuts, the squirrels and chipmnks guarantee that there is no clean up around here.
Cults require delusions. |
Information Overloader
I'm told they do make vacuums to suck the nuts up. I think they're sometimes called Wanda or Cynthia.
For some unknown reason, trees 'mast' every so often. That is they produce unusually huge numbers of seeds, up to 10X normal. Usually abuncha trees of the same species and in close proximity to each other do it all at the same time. It probably has some ecological purpose. |
Picking them up today...I spent 2 hrs raking and shoveling.
I'm 67 and it's getting old. Pushing a 6 cu/ft wheelbarrow, full of walnuts, 100 yds away...is not my idea of a good afternoon. I have better things to do.
The squirrels come around to get them later on....right now they are watching and laughing.
[QUOTE=Crowbob;11482154]I'm told they do make vacuums to suck the nuts up. I think they're sometimes called Wanda or Cynthia.
I will look for that.
^^^ lol
You do not have permissi
That was the entire point. Let nature do her thing. You control the rest. Tree bases often look stark and empty (a plain horizontal intersecting a series of vertical) without a cushion. That is a good thing when the yard needs to seamless and larger. You would probably want a view of the street. But a big enough plot can be broken up. Plant hearty bushy perennials at the edge of the tree base perimeter to cover and soften it up from the street view. Not a botanist here. PM me if transplants(extra butterfly bush and rose-of-sharon) are even worth a full days drive.
Meanwhile other things are still happening. Last edited by john70t; 10-11-2021 at 02:27 PM.. |
First, please don't cut that tree down.
2nd, I would suggest working on your core. Back pains generally are weak core muscles. 3rd, If that doesn't sound appealing try a billygoat lawn vacuum. When I was in the lawn business many, many years ago we used leaf vacums. This was in the day before the landscapers used blowers to blow everything in the street. Looks like this guy made his own with a trailer? |
^^^ John
I see your point....would prob work for a smaller tree. This tree drops so many nuts that I can't even walk under the tree (without twisting an ankle) The ground is completely covered with nuts until I remove them...which has to happen before mowing.
I have the same (Trac-Vac) and it won't suck-up nuts.
If the wife doesn't want to cut the tree down, you can always accidently burn it down by inadvertently dumping a couple gallons of fuel oil around the base and trying out that cool lighter you happened to find right next to it.
Or go on a couple days vacation and forget to cancel the tree and stumpgrinder appt. somebody scheduled on the same exact days. |
I doubt the ****tree would burn.
67? You are doing very fine, sir.
Make it easy for yourself. Don't fret. Don't bother mowing the base of the tree. Weed-whack it once or twice a year and as they say "forget about it".
Meanwhile other things are still happening. Last edited by john70t; 10-11-2021 at 02:41 PM.. |
Burn a walnut tree where dollars are measured by the square inch?
Oh la la la. Non non non. C'est sacre blue!
Meanwhile other things are still happening. Last edited by john70t; 10-11-2021 at 02:43 PM.. |
Thank you! The balance of the lawn is very nice. If I just leave them...they will build up to a site-sore. I have to either eliminate the tree (which I don't want to do) or find an easier way to clean up the nuts.
advice needed on black walnut tree
My big walnut tree is crazy this year. Definitely not a yearly or every other year thing. Nuts and squirrels everywhere. I just run the nuts over and let nature take its course. I cut the small walnut trees down that sprout as I don’t want any more of those awful plants around! Sent from my iPhone using Tapatalk |
