beatnavy's Avatar
Porch Ceiling Finishing Question
On my old house I have three different porch ceilings that were done years ago with sheetrock/drywall, and now they really need to be redone as the paint is chipping and the seam tape has come out in most places. I've got a small one upstairs (~15 x 9), the main one on front of house (~40 x 10), and a carport (maybe 30 x 10). I was first going to tackle the smaller one first myself using an Azek or Azek type tongue and groove material that's pretty thin. Still trying to decide on how to refinish the other two.
I don't know what's under that drywall, but my initial thought was just to put the Azek on top of the drywall (e.g., leave the sheet rock in place.) My neighbor, whose opinion I value highly, said "No! You'll get mold on the drywall. Take it down and put plywood in its place." We DO live in a very humid area, but there's no sign of mold currently. I could see covering it up would reduce airflow and possible contribute to that.
I don't mind taking the drywall out and putting the plywood in if that's the best way to do it, but I wanted to get other opinions on whether that's necessary. This ceiling does connect to the attic above living space.
Thoughts?
Rob C.
'72 914 2056
'75 914 Project
Old 10-25-2021, 10:35 AM
911_Dude's Avatar
Definitely ply, or anything but drywall. You can get it with some decorative design such as beadboard. Way lighter than drywall and no mudding/taping. You arms will thank you.
Old 10-26-2021, 03:45 AM
scotricker's Avatar
oh, wait, the other kind of porch
Scot
78 911SC coupe, sold,, 2019 Macan S
"my friends all drive Porsches, I must make amends.."
Old 10-26-2021, 12:24 PM
beatnavy's Avatar
Ok, thanks for the help! Yeah, I ended up having time to run errands yesterday and ended up buying ply/sheathing and enough Azek to do the smaller porch. Today I got the drywall out and the ply up. Tomorrow it's laying the tongue and groove.
Rob C.
'72 914 2056
'75 914 Project
Old 10-26-2021, 01:43 PM
First- mold spores are ever present. Three things need are a food source, moisture and heat remove anyone and mold wont grow.
Is he saying plywood then Azek or just plywood?
You can remove the sheetrock and apply your replacement material directly to the joists.
Old 10-26-2021, 02:50 PM
Parrothead member
VINMAN's Avatar
Bead board (wainscot..) was always the long time standard for porch ceilings. I ve used tongue and grove pine, FRP, barnwood. All depends on the final look you want.
Sheetrock is a huge no no..
Vinny
Old 10-26-2021, 03:13 PM
Brew Master
cabmandone's Avatar
What does the rest of the house look like? It might be easier to suggest a material based on the exterior appearance. The easy material IMO is solid vinyl soffit material. But it really depends on what the home looks like and what product would best match the exterior.
Nick
Old 10-26-2021, 05:26 PM
beatnavy's Avatar
I ended up buying the Azek PVC beadboard planks. This stuff: https://azekexteriors.com/products/specialty-items/beadboards/beadboard
It should match the house well, which is colonial in style with white siding and porch columns. I wanted to put the plywood up partially to provide additional sealing/insulating (I know, not much R-value), but mainly because I'm running the boards parallel to the joists in this specific application.
Hopefully I'll like this stuff and maybe use it on the other porches. Same neighbor I referenced used it for a recently renovated interior ceiling and he loves it.
Thanks for the input!
Rob C.
'72 914 2056
'75 914 Project
Old 10-26-2021, 06:01 PM
Bill Douglas's Avatar
Oh, that's quite stylish.
It will be an enhancement to the place.
Old 10-26-2021, 07:33 PM
