A cool video of engine with transparent cylinder running.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 10-25-2021, 08:56 AM
(the shotguns)
berettafan's Avatar
They say a picture is worth 1000 words....
What an absolutely AWESOME video!
Old 10-25-2021, 09:12 AM
I never knew that acrylic would hold up to that much heat.
But he never held it wot for long...maybe that's why.
98 Honda Prelude
22 Honda Civic SI
Old 10-25-2021, 09:23 AM
That video is the best. Consider all that is happening along with all the forces. Amazing that cars can run 200k or more miles. I like the image of the burning of the fuel - looks like it is happening all at one time. You can see the fire happen just before TDC.
Sold: 1989 3.2 coupe, 112k miles
Old 10-25-2021, 09:24 AM
The valves get close to the piston on the "overlap" stroke. Not much room to be off in valve timing on an interference motor.
Old 10-25-2021, 09:28 AM
Top notch video on all accounts.
18 Cayman GTS
Old 10-25-2021, 10:14 AM
IROC's Avatar
We did something similar here at work, but used neutrons to "see" through the aluminum...
https://www.youtube.com/watch?v=BYXy5CYN9TQ
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 10-25-2021, 10:23 AM
Still Doin Time
asphaltgambler's Avatar
GM developed a single cylinder test engine that employed a camera lens in the cylinder head in the early 50's where they could adjust the stroke and then compression ratio and vary levels of octane fuel introduced. I'm not sure if the film is out there on the 'net, but I've seen it, very cool
Old 10-25-2021, 11:20 AM
pwd72s's Avatar
Yeah. I'd have been worried about acrylic shards flying about.. Amazing video. Thanks.
Old 10-25-2021, 11:31 AM
You do not have permissi
john70t's Avatar
How Does A Carburetor Work? | Transparent Carburetor at 28,546 fps Slow Mo - Smarter Every Day 259
Old 10-25-2021, 12:25 PM
My old small block 305 in the El Camino went 301,000 miles. The rings were pretty worn as were the valve guides so it was smoking more than I liked. The heads were never off of it until I pulled that engine out the vehicle. I only took off the heads because I was curious to see the innards. It ran just fine, just too smoky for me.
The video is just what my mind's eye figured happened in the there. I just can't image how the old F1 engines ran at 18,000 RPM.
Old 10-25-2021, 01:07 PM
I liked how the video just showed the build...instead of how some talk through the whole works.
He did a great job.
98 Honda Prelude
22 Honda Civic SI
Old 10-25-2021, 02:20 PM
LWJ LWJ is online now
Very cool. Thanks!
Old 10-25-2021, 02:35 PM
Edministrator
Steve Carlton's Avatar
You should have used transparent aluminum!
Good post? Leave a tip!
O - $1
O - $2
O - $3
Old 10-26-2021, 04:28 PM
A930Rocket's Avatar
Cool. Was it the video or was the fuel not atomized as much as I thought it would be? I thought it would be more of a fog or mist, but it actually looks like droplets.
Old 10-26-2021, 05:22 PM
I assume a real carburetor would do a better job of making a consistent fine mist. This is one advantage of fuel injection.
Old 10-26-2021, 06:22 PM
Preferred pronoun:Maestro
Norm K's Avatar
Cool video, to be sure, but I thought conversations about things like transparents were restricted to PARF.
_
When in doubt, use overwhelming force.
Old 10-26-2021, 07:30 PM
