A cool video of engine with transparent cylinder running.
<iframe width="560" height="315" src="https://www.youtube.com/embed/nvMcFQqhbpM" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
They say a picture is worth 1000 words....
What an absolutely AWESOME video! |
I never knew that acrylic would hold up to that much heat.
But he never held it wot for long...maybe that's why. |
That video is the best. Consider all that is happening along with all the forces. Amazing that cars can run 200k or more miles. I like the image of the burning of the fuel - looks like it is happening all at one time. You can see the fire happen just before TDC.
The valves get close to the piston on the "overlap" stroke. Not much room to be off in valve timing on an interference motor.
Top notch video on all accounts.
We did something similar here at work, but used neutrons to "see" through the aluminum...
https://www.youtube.com/watch?v=BYXy5CYN9TQ |
GM developed a single cylinder test engine that employed a camera lens in the cylinder head in the early 50's where they could adjust the stroke and then compression ratio and vary levels of octane fuel introduced. I'm not sure if the film is out there on the 'net, but I've seen it, very cool
How Does A Carburetor Work? | Transparent Carburetor at 28,546 fps Slow Mo - Smarter Every Day 259
<iframe width="560" height="315" src="https://www.youtube.com/embed/toVfvRhWbj8" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> |
The video is just what my mind's eye figured happened in the there. I just can't image how the old F1 engines ran at 18,000 RPM. |
I liked how the video just showed the build...instead of how some talk through the whole works.
He did a great job. |
Very cool. Thanks!
Cool. Was it the video or was the fuel not atomized as much as I thought it would be? I thought it would be more of a fog or mist, but it actually looks like droplets.
Cool video, to be sure, but I thought conversations about things like transparents were restricted to PARF.
_ |
| All times are GMT -8. The time now is 01:27 PM. |
