A cool video of engine with transparent cylinder running.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
(the shotguns)
They say a picture is worth 1000 words....
What an absolutely AWESOME video!
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
I never knew that acrylic would hold up to that much heat.
But he never held it wot for long...maybe that's why.
That video is the best. Consider all that is happening along with all the forces. Amazing that cars can run 200k or more miles. I like the image of the burning of the fuel - looks like it is happening all at one time. You can see the fire happen just before TDC.
Sold: 1989 3.2 coupe, 112k miles |
The valves get close to the piston on the "overlap" stroke. Not much room to be off in valve timing on an interference motor.
Top notch video on all accounts.
84 930 18 Cayman GTS |
We did something similar here at work, but used neutrons to "see" through the aluminum...
https://www.youtube.com/watch?v=BYXy5CYN9TQ
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Still Doin Time
GM developed a single cylinder test engine that employed a camera lens in the cylinder head in the early 50's where they could adjust the stroke and then compression ratio and vary levels of octane fuel introduced. I'm not sure if the film is out there on the 'net, but I've seen it, very cool
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Yeah. I'd have been worried about acrylic shards flying about.. Amazing video. Thanks.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
You do not have permissi
How Does A Carburetor Work? | Transparent Carburetor at 28,546 fps Slow Mo - Smarter Every Day 259
Meanwhile other things are still happening. |
The video is just what my mind's eye figured happened in the there. I just can't image how the old F1 engines ran at 18,000 RPM.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
I liked how the video just showed the build...instead of how some talk through the whole works.
He did a great job.
Very cool. Thanks!
Edministrator
Good post? Leave a tip! O - $1 O - $2 O - $3 |
Cool. Was it the video or was the fuel not atomized as much as I thought it would be? I thought it would be more of a fog or mist, but it actually looks like droplets.
I assume a real carburetor would do a better job of making a consistent fine mist. This is one advantage of fuel injection.
Preferred pronoun:Maestro
Cool video, to be sure, but I thought conversations about things like transparents were restricted to PARF.
_
When in doubt, use overwhelming force. |
