I ran a 20 amp circuit for the dishwasher and a separate 20 amp circuit for an over the range microwave. Except for the GFCI issue I think I’m good.
20 amp for DW is plenty. You oven should be gas and not elec? 20 amp is not enough for elec oven, normally. Pop in that GFI in the panel for the DW and you are good to go.
Any appliance in the kitchen that has a motor or heats water must be on a dedicated circuit. Two small appliances circuits are required for the entire kitchen counter area |
You do not have permissi
They cleaned up a bunch of stuff in the meantime and were there a while. It needed to be done. New tenant had an outage recently. Electric stove burners, plus oven, plus tv were running but the individual breakers didn't trip which freaked me out. Then tenants admitted the space heater was going as well. It turns out the main shut-off for that apt is only 60amp (electrician check the operation) so that was the weakest chain in the system but it worked as it should. I've got a new stove on order just to be safe.
Meanwhile other things are still happening. |
Formerly reformed
Isn't there also supposed to be a separate circuit for a vent hood? Sent from my iPhone using Tapatalk
1968 911P (Paperweight) |
Little power is needed to keep the oven light or the fan running if its a convection oven. It takes even less power to keep the piezo ignition, I call that the spark plug, to light the cook tops. Is it self cleaning? That may require big elec power. If gas, then there's no need to worry power. A regular plug is all it will need to safely operate that stove for years to come.
When we do our kitchens, we pull 8-10 dedicated circuits. Some odd things like instant hot drinking water, microwave and such must have its own dedicated circuit. |
