What's a good ODB2 dongle to display data on phone?
There's all sorts of opinions on various race/track forums about what works but I thought I'd come to the real internet brain trust, Pelican, for the best answer.
I'd like something to record standard RPM, temps, etc on my phone but also display engine temp which modern Porsche's seem to fudge on the dash display (it always shows 194° unless something goes really wrong).
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Parrothead member
I use Torque Pro for my vehicles. Mainly for my diesels. Uses a obd bluetooth adapter. Works great very happy with it. you can download the profile for your vehicle and set with parameters you want displayed.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
Super Moderator
Most of the dongle's work about the same. Its the software that really makes the difference.
canna change law physics
This is the one I use. Cheap and small. You can leave it in the port all the time. https://amazon.com/Panlong-Bluetooth-Diagnostic-Scanner-Android/dp/B00PJPHEBO/ref=sr_1_17?keywords=odb2+scanner+bluetooth&qid=1641567173
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Parrothead member
^^^ Same one I use. Have a couple. Advanced Auto sells a similar one. ( I'm pretty sure they all probably come from the same factory in china...
The Unsettler
Agreed.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Wow, that Torque Pro looks amazing. It ought to be a lot more popular. I never understood why all of the valuable data such as oil pressure, head temp, etc are not displayed in factory gauges. You can query the ECU with a Durametric for over-rev history. It will tell you how many over rev rotations were made in each rpm range.
I just added a third radiator to my Cayman but unfortunately didn't check Durametric engine temps until after the work was done. Now the Durametric is showing really high engine temperature of 114°C (237°F) which can't be correct. I say can't be correct because supposedly the dash always shows a temperature of 194°F if the temperature is between 185-215°F. Here's my dash and the Durametric readings when driving on the highway with a full warmed engine:
Are the two readings in the same place? What are the specific instruments being used? In regular automotive applications, thermistors are used. 4 wire RTDs are more accurate in the temperature range. Thermistors are "good enough" for most things, are cheaper and only require 2 wires.
One reading is in F, and the other C. Maybe they're close enough?
102C = 215F 219F = 104C |
I should also offer my own experience with adding a third radiator. I had an air bubble that caused scary high temperatures. I got an Airlift vacuum filler, and now no more air bubble.
Dashcmd if you have an iphone. It's the equivalent to torque pro for IOS.
I would do a vacuum fill on your cayman. It's worth the $100 to buy an airlift system and you will never have to worry about bleeding it. Last edited by RedBaron; 01-09-2022 at 05:46 AM.. |
Recreational Mechanic
I have an OBDLinkMX and it works great.
https://www.amazon.com/OBDLink-Bluetooth-Professional-Grade-Diagnostic-Performance/dp/B07JFRFJG6/ref=sr_1_2?crid=3JBEIG926DKU5&keywords=obdlink+mx&qid=1641739653&sprefix=obdlink+mx%2Caps%2C94&sr=8-2 There are many phone apps you can use it with. OBDLink's own, Torque Pro, etc.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
The Unsettler
Bought mine right at the end of 2019 and paid half as much.
It is the one recommended by many of the apps out there.
When I search Torque Pro, I don’t see anything with that exact title in the iOS App Store.
Anybody have a link? Edit: I’ve been using OBDLink and a Bosch app. |
Parrothead member
Try Google Play
Torque pro isn't on iOS. The closest app is dashcommand.
Gon fix it with me hammer
https://bimmercode.app/adapters/
If bimmercode supports em, they'll be pretty good Cause they code bimmers with it, and well, it's the more fancy work you would do with an odb adapter why is everybody talking about apps when the question is bout hardware?
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 Last edited by svandamme; 01-09-2022 at 09:57 AM.. |
