David's Avatar
What's a good ODB2 dongle to display data on phone?
There's all sorts of opinions on various race/track forums about what works but I thought I'd come to the real internet brain trust, Pelican, for the best answer.
I'd like something to record standard RPM, temps, etc on my phone but also display engine temp which modern Porsche's seem to fudge on the dash display (it always shows 194° unless something goes really wrong).
Old 01-07-2022, 05:38 AM
Parrothead member
VINMAN's Avatar
I use Torque Pro for my vehicles. Mainly for my diesels. Uses a obd bluetooth adapter. Works great very happy with it. you can download the profile for your vehicle and set with parameters you want displayed.
Vinny
Old 01-07-2022, 05:59 AM
Super Moderator
cstreit's Avatar
Most of the dongle's work about the same. Its the software that really makes the difference.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-07-2022, 06:40 AM
canna change law physics
red-beard's Avatar
^^^This. And the Torque Pro is what I use.
This is the one I use. Cheap and small. You can leave it in the port all the time.
https://amazon.com/Panlong-Bluetooth-Diagnostic-Scanner-Android/dp/B00PJPHEBO/ref=sr_1_17?keywords=odb2+scanner+bluetooth&qid=1641567173
James
Red-beard for President, 2020
Old 01-07-2022, 06:54 AM
Parrothead member
VINMAN's Avatar
^^^ Same one I use. Have a couple. Advanced Auto sells a similar one. ( I'm pretty sure they all probably come from the same factory in china...
Vinny
Old 01-07-2022, 11:27 AM
The Unsettler
stomachmonkey's Avatar
Agreed.
"I want my two dollars"
"Brandon Won"
Old 01-07-2022, 12:47 PM
Wow, that Torque Pro looks amazing. It ought to be a lot more popular. I never understood why all of the valuable data such as oil pressure, head temp, etc are not displayed in factory gauges. You can query the ECU with a Durametric for over-rev history. It will tell you how many over rev rotations were made in each rpm range.
Old 01-07-2022, 01:30 PM
David's Avatar
I just added a third radiator to my Cayman but unfortunately didn't check Durametric engine temps until after the work was done. Now the Durametric is showing really high engine temperature of 114°C (237°F) which can't be correct. I say can't be correct because supposedly the dash always shows a temperature of 194°F if the temperature is between 185-215°F. Here's my dash and the Durametric readings when driving on the highway with a full warmed engine:
Old 01-08-2022, 07:04 AM
red-beard's Avatar
Are the two readings in the same place? What are the specific instruments being used? In regular automotive applications, thermistors are used. 4 wire RTDs are more accurate in the temperature range. Thermistors are "good enough" for most things, are cheaper and only require 2 wires.
James
Old 01-08-2022, 01:07 PM
One reading is in F, and the other C. Maybe they're close enough?
102C = 215F
219F = 104C
Old 01-09-2022, 12:20 AM
I should also offer my own experience with adding a third radiator. I had an air bubble that caused scary high temperatures. I got an Airlift vacuum filler, and now no more air bubble.
Old 01-09-2022, 12:29 AM
RedBaron's Avatar
Dashcmd if you have an iphone. It's the equivalent to torque pro for IOS.
I would do a vacuum fill on your cayman. It's worth the $100 to buy an airlift system and you will never have to worry about bleeding it.
Old 01-09-2022, 05:37 AM
Recreational Mechanic
Nickshu's Avatar
I have an OBDLinkMX and it works great.
https://www.amazon.com/OBDLink-Bluetooth-Professional-Grade-Diagnostic-Performance/dp/B07JFRFJG6/ref=sr_1_2?crid=3JBEIG926DKU5&keywords=obdlink+mx&qid=1641739653&sprefix=obdlink+mx%2Caps%2C94&sr=8-2
There are many phone apps you can use it with. OBDLink's own, Torque Pro, etc.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 01-09-2022, 06:47 AM
The Unsettler
Originally Posted by Nickshu View Post
Wow that got expensive.
Bought mine right at the end of 2019 and paid half as much.
"Brandon Won"
Old 01-09-2022, 07:11 AM
Nickshu's Avatar
Wow. Mine is actually the older MX model (Before the "plus") and if I recall yes it was about $60 a few years ago.
It is the one recommended by many of the apps out there.
Old 01-09-2022, 07:15 AM
A930Rocket's Avatar
When I search Torque Pro, I don’t see anything with that exact title in the iOS App Store.
Anybody have a link?
Edit: I’ve been using OBDLink and a Bosch app.
Old 01-09-2022, 08:25 AM
Parrothead member
VINMAN's Avatar
Try Google Play
Vinny
Old 01-09-2022, 08:26 AM
A930Rocket's Avatar
Originally Posted by VINMAN View Post
Try Google Play
Looks like a android based app and not iPhone compatible.
Old 01-09-2022, 09:30 AM
RedBaron's Avatar
Torque pro isn't on iOS. The closest app is dashcommand.
Old 01-09-2022, 09:48 AM
Gon fix it with me hammer
svandamme's Avatar
https://bimmercode.app/adapters/
If bimmercode supports em, they'll be pretty good
Cause they code bimmers with it, and well, it's the more fancy work you would do with an odb adapter
why is everybody talking about apps when the question is bout hardware?
Stijn Vandamme
BIMDIESELBMW116D2019
Old 01-09-2022, 09:55 AM
