-   -   Source for Plastic tail light material? (http://forums.pelicanparts.com/off-topic-discussions/1110181-source-plastic-tail-light-material.html)
ErVikingo 01-07-2022 01:24 PM
I'm in need of plastic to make replacement lenses for some tail lights. No need for them to be "Fresneled" actually, plain would be ideal.
The lens will be almost flat and glued to the lamp fixture.
Thanks in advance!
rusnak 01-07-2022 01:36 PM
You might search for plastics manufacturing near you. It can be expensive, but you get what you pay for. I've used Precision Plastic near me to have custom stuff manufactured. Way better than I could ever do myself.
ErVikingo 01-07-2022 01:41 PM
Great! Thanks for the feedback.
asphaltgambler 01-07-2022 01:50 PM
Have you thought about repurposing from an existing style that is already in production?
ErVikingo 01-07-2022 02:00 PM
I did Sir but the lens I have to make is quite large (4x23 each).
Placed a call to local plastic supply place. Guess I'm getting "sign" material.
Next up, how to cut it carefully..... patience
Cheers!
rusnak 01-07-2022 02:48 PM
A plastic manufacturer will have the piece cut, drilled and ready to install to your specifications. A distributor will simply sell you existing generic stock.
asphaltgambler 01-07-2022 02:49 PM
^^^^^^^^good call
JackDidley 01-07-2022 02:55 PM
How about this ??
https://www.amazon.com/Acrylic-Plexiglas-Plastic-Sheet-2283/dp/B00JV3NPHM
ErVikingo 01-07-2022 04:06 PM
True. Thanks for that insight.
ErVikingo 01-07-2022 04:07 PM
Originally Posted by JackDidley (Post 11568864)
I’ll send them a message to confirm the level of translucence. It says they do custom cuts!
Nostril Cheese 01-07-2022 05:40 PM
TAP Plastics. Use them all the time.
https://www.tapplastics.com/
ErVikingo 01-07-2022 07:37 PM
Thanks NC!
sc_rufctr 01-07-2022 08:07 PM
Interesting and relevant video... Note how he uses a clean open flame to soften and mould the plastic.
<iframe width="560" height="315" src="https://www.youtube.com/embed/pjeSfKMiBP4" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
otto_kretschmer 01-08-2022 06:57 PM
If you're savy enough to make a positive mold out of wood, or bondo and then make a negative mold out of 2 part rubber, you can make a lens out of this stuff.
https://www.plastex.net/
unclebilly 01-08-2022 07:06 PM
3D print them?
otto_kretschmer 01-08-2022 07:18 PM
Originally Posted by unclebilly (Post 11569980)
3D print them?
you would need a CAD file and then a makerbot or some other 3D printer
I have a project that I started years ago and keep putting on the back burner for making a fiberglass or carbon fiber tail light assy
I built the master out of styrofoam and bondo
Bill Douglas 01-08-2022 07:33 PM
And if they need the DOT or EU compliant number on them you could buy cheap trailer lights and cut out the bits with the numbers and melt that in.
Bill Douglas 01-08-2022 08:21 PM
Talented guy.
unclebilly 01-09-2022 05:34 AM
Seriously, the 3D printed solution is the way to do this. Get a 15 year old neighborhood kid with a printer to help. It will cost you $100 and be done and awesome.
If we were closer, my 11 year old would do this for you.
Welcome to 2018…
drew1 01-09-2022 05:40 AM
A sign manufacturer may give you scrap off their shear.
