-   -   WTF... no Dino oil at the Mart !! (http://forums.pelicanparts.com/off-topic-discussions/1111348-wtf-no-dino-oil-mart.html)
74-911 01-23-2022 01:48 PM
Went to the Mart to pickup a couple of quarts of Walmart brand Dino 10W-40 for the lawn tractor. Lots of Synthetic and synthetic blend of every brand starting at 6-7$ s qt. After digging around finally found a couple of qts. of Valvoline 10W-40. Guess I should have seen this coming.
Fortunately I have 24 qts of Valvoline VR-1 20W-50 I picked up off WOOT.COM 5-6 months ago at about 1/2 price. Afraid to see what it is now.
GothingNC 01-23-2022 02:06 PM
Amazon has a 6 pack of the Valvoline VR-1 20W-50 for $25
flatbutt 01-23-2022 02:08 PM
Beat me to it. I just bought two jugs of high zinc for the Duc.
pmax 01-23-2022 02:34 PM
Synthetic
stevej37 01-23-2022 02:38 PM
We need another Autozone closeout sale on VR1 for $1/qt.
I picked up 76 quarts...I'm down to about 10 now.
mo713 01-23-2022 03:21 PM
What is VR-1? Can it be used in import cars? And why are there deals? Is it on closeout or something?
I actually use 20w-50 always. It's usually harder to find wherever you go.
stevej37 01-23-2022 03:44 PM
^^^ SmileWavy
https://m.media-amazon.com/images/I/...AC_SL1500_.jpg
http://forums.pelicanparts.com/uploa...1642981454.jpg
mo713 01-23-2022 03:59 PM
So, what's the deal with the extreme discounts? This looks like it would be expensive...
stevej37 01-23-2022 04:02 PM
If you look at the two pics above...you'll notice the label is different.
Valvoline needed to change the label....thus they discounted all their VR-1
AutoZone sold all their inventory for $1/qt until it was gone.
I had to go to 4 diff stores to get 76 quarts.
red-beard 01-23-2022 06:01 PM
Amazon Basics Dino is 18.54 for 5 qts.
Synthetic High Mileage is 22.98 for 5 qts
stevej37 01-24-2022 08:04 AM
My walmart is sporadic on almost everything lately.
Last week they were out of all eggs for three days. A couple days later...they were fully stocked on all grades.
T77911S 01-24-2022 08:16 AM
try to find oil that is not 0-X, 5-x. maybe even 10-x
amsoil or FCP euro and never pay for oil again.
svandamme 01-24-2022 12:35 PM
huh???
how is 10w40 dino oil ?!?!
As far as I know and can read, the very fact that 2 weights are indicated, means it will be synthetic as dino oil can't do that!?!?
stevej37 01-24-2022 12:46 PM
^^^ Either one can be made in multiple weights.
The VR-1 pictured above would be a dino oil.
If it's synthetic...it must say it on the container.
svandamme 01-24-2022 01:05 PM
to my knowledge any multigrade, with mineral oil in it, would be called semi-synthetic
there's no full mineral multigrade oil, not possible.
EDIT, guess i was wrong then
https://www.shell.com/business-customers/aviation/aeroshell/knowledge-centre/technical-talk/techart07-30071235.html
cockerpunk 01-24-2022 01:15 PM
why wouldnt you want synthetic oil?
its literally better at everything. all the time.
svandamme 01-24-2022 01:21 PM
some say, older engines tend to start leaking if you change from dino to synthentic
cockerpunk 01-24-2022 01:23 PM
thats a sign the oil is better, and your engine is not sealed well. fix the seals, and enjoy better engine lubrication and less wear.
stevej37 01-24-2022 01:33 PM
"Fix the seals"...easy to say, not so easy to do.
If the car has always used dino...why switch?
cockerpunk 01-24-2022 01:35 PM
if you have a leaking engine, then you need to fix the seals one way or another. if your oil is solid, you'll have no leaks at all!
because synthetic is better for everything. less wear on cold starts, higher temp protection, longer change intervals, its better, pure and simple.
