Excel - my turn for help
I'm knowledgeable in the use of Vlookup. In this specific case - first time I'm trying to do this - I want to use two numbers in two different cells as part of the lookup range.
Example A1 contains "500" = this represents the start row 500 in a data array C:Z on Sheet 2 B1 contains "1000" = this represents the end row 1000 in the same data array C:Z These 2 values change based on data in the C:Z array - via different formulae. They might be 500,1000 today, but 750,2000 someday next week. That is solved. A10 contains a value, I want to return a value from the C:Z array column D that corresponds to it. My Vlookup formulae without using A1 and B1 would currently be =Vlookup(A10,'Sheet2'!C500:Z1000,2,0) How do I inject the value of A1 and B1 into the vlookup formula? Well _ I should have known as soon as I posted the question, I'd figure it out. The answer is use of the INDIRECT function.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? Last edited by MBAtarga; 02-18-2022 at 12:32 PM.. |
