Proof There ARE Stupid Questions
From me.
LSS, I bought a small Honda Generator EU2000i to power the well at the stable last year. Very portable for my wife. My company was also going to be involved in two site flight test and I bought a second EU2000i to power ground control station, etc. at the same time. Also, I bought a new electric start generator for the house since my wife has a hard time pull starting the larger generator. So I have spare capacity. We have not needed either one of the Honda's and they are still NIB, unopened. My question: They have not been gassed or oil put in. Any idea how long they can be stored NIB? I am assuming years. I have done a bit of poking around on the interwebs and can find nothing. I'll call Honda after you guys stop making fun of me
1996 FJ80. Last edited by Seahawk; 02-19-2022 at 08:53 AM.. |
Senior Member
Good question.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Model Citizen
Seals dry out. Condensation happens. Rust never sleeps.
I think it's a very apt question.
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
1996 FJ80. |
Senior Member
Well.....engines parts can be protectively coated and I suppose the coatings can be effective and last a "long" time ("long" being undefined here). But then there are the electrical parts and the generator/alternator windings are going to be exposed. We know these manufacturing preparations can protect for a time, but we also know that time is not forever. A question of when, I suppose. Worst case scenario....you run them every six months for several minutes or so. Or perhaps once per year, and fog the engine before storage.
I see you
I run my honda every 6 months in the hope that doing so will keep bad things from happening.
Would the other shoe be you selling one?
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Information Overloader
I also do what Sup recommends. I just don't want to pull the two out of the box until I have to because routine maintenance often isn't ![]() I plan on keeping them. They will be perfect for South Carolina and the small camping trailers I am looking at.
1996 FJ80. |
Thanks!
1996 FJ80. |
I have a Honda powered mower. My son put the Honda engine on a Snapper chassis for me when he was in high school. That mower sat, unused for over a year and a half while I had my heart issues. When I went to start it up again, all I did was prime it with a couple of pulls to get the oil (old Bradd Penn oil from my SC) circulated, sprayed some starting fluid in the air cleaner (the throttle cable handle is broken off so it's always on the rabbit setting ie FULL Throttle) and gave it a pull. Fired right up no problem. And on year and a half old gas too.
Since your's haven't been run I don't think you'll have a problem if the tanks aren't rusty inside.
Scott '78 SC mit Sportomatic - Sold |
Make Bruins Great Again
The thread title reminds me of a great quote (no reflection on the post creator)
"There are no stupid questions but there are some amazingly inquisitive idiots"
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Platinum Member
I think I would fog the cylinders
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Edministrator
Why not sell one or both and re-acquire when needed? You'll probably have your Lightning by then, anyway...
Good post? Leave a tip! O - $1 O - $2 O - $3 |
Senior Member
They might already be coated with the cylinder wall equivalent of "assembly lube."
Brew Master
There's assembly lube in the engines so I wouldn't get too worried. Are you storing them in a climate controlled building that doesn't see a lot of temperature swing?
Exactly what I was thinking. The cylinder walls would typically have some sort of lubricant applied prior to the pistons being installed. I don't know if Honda test fires their small engines or not though. If test fired even for a short period of time, the assembly lube on the cylinder walls would be gone.
Nick Last edited by cabmandone; 02-19-2022 at 11:32 AM.. |
weekend wOrrier
Honda guarantees the first start regardless.
Ethanol will probably do more harm than the year of storage most likely ever would. If it doesn't have oil, it was never started, so the assembly lube is probably still there. I see 40+ year old garden tractor engines NOS go up for sale all the time. Any rust on the inside of a new tank is less than the rust on a used older tank. Most older used tanks look like the hold of a sunken ship, if not pin hole rusted through. Yours will be fine. edit- another clue... yours are in a box. Is the cardboard rotted away? If not, the engine has been exposed to less moisture than the amount needed to mess up cardboard. The NOS kohlers I see are unpainted raw, never came in a box, and have sat on a shelf since Carter was president, perhaps even Nixon. Light surface rust if anything. Last edited by LEAKYSEALS951; 02-19-2022 at 05:12 PM.. |
My thought was "new in a box, should be fine," but I didn't comment because I don't know enough to comment.
A car I have listed for sale, stating that it is basically , a barely street legal track car, with pictures.
![]() See any wipers?? ![]() ![]() ![]() ![]() ![]() ![]() I got an email asking if it had AC ![]() Lexan windows and does it have AC, lol.
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
weekend wOrrier
Unless he's been storing them down by his shoreline under the retaining wall, I think he's fine.
![]() God Byron, that's the cleanest newestest? 944 engine I've ever seen. But I don't see a turbo in the second pic, or a steering wheel, are they included? How bout wipers? Power windows? Door panels? Last edited by LEAKYSEALS951; 02-19-2022 at 05:07 PM.. |
