Just another bribe for votes. This time farmers and the AG industry.
I want to say, maybe in the early 1980s there was a tech article in Road & Track about oxigenated fuel, and how the Fed EPA might mandate it's use in order to force vehicles to run lean. I was maybe 12 or so when I read it, so I didn't fully understand all of it, but I was aghast at the fact that they would mess with the fuel that you buy, making it less efficient.
And here we are today with the (literally) pisswater gasoline that will destroy your vehicle. |
Again, nothing in this is correct, that is not why ethanol was added to fuel, no matter how many times you say so. |
OK, so your ECU or "Motronic" (Bosch L-Jetronic in other words) will take over and go into closed loop once the O2 sensor heats up. You'll notice that it will lean or richen the fuel mixuture until it gets to .99 to 1.01 Lambda. It does not allow your vehicle to run lean or rich. If your AFR is showing a lean mixture, then your fuel injection system is broken. I wrote a quite lengthy description of all this on Rennlist way back about 12 or 14 years ago. |
It always runs on stored maps. With the 02 sensor or without.. it's running on stored fuel maps.
What I mean is, If I'm at WOT I'm running on the WOT fuel map that changes the AFR to around 12.9-13 At tip in I might go from 14's down into the mid 13 range At idle I'm set at around 14.2 but when I put pure gas in, for some reason that number drops into the range I've mentioned. |
I didn't know Vettes were flex fuel vehicles! So if nothing else comes from this thread, at least I've learned that.
Interesting. I guess I've never looked into what makes a flex fuel vehicle different from a non flex fuel vehicle.
Bosch Motronic is unable to run closed loop at WOT.
Oxygen sensor has no input, uses preset maps to fuel the engine. In stock form you will find that it’s a fairly rich AFR. I recall when oxygenated fuels first came out. Some dyno runs with sport bikes showed an increase in power. You could get disqualified in racing using pump gas vs high octane race gas if they were fuel testing that weekend. |
My F150 that was Flex Fuel would go from 17 MPG to 13 on Ethanol. Not cheaper in the long run at all
1 fossil fuel is stored carbon in the earth 2 dug or pumped up.. 3 burnt to release CO2 in the atmosphere ENDprogram 1Ethanol is grown on a field, absorbes CO2 2turned to ethanol 3burnt to release CO2 in the atmosphere 4 Go to 1 it's BS, but ok, that's the concept |
| All times are GMT -8. The time now is 12:04 AM. |
