-   -   Better, but not best, for occasional use chain saw (http://forums.pelicanparts.com/off-topic-discussions/1115581-better-but-not-best-occasional-use-chain-saw.html)
masraum 03-26-2022 01:47 PM
We have some trees/branches on the property that need to be cut up. I need more grunt and cutting time that I get from my little electric chain saw. I need a "real" ;) chain saw. There is a local store that is a "Farm Service Center" that sells everything including Stihl. I think those are well regarded.
I want a decent chain saw that's going to work well and last, but I don't need the best chain saw.
Does anyone have any recommendations on what I should get or what I should look for? Are there any questions that I need to answer to be able to answer this question?
This thing may go a year or two without being used, but then be needed for several hours at other times.
I believe I've seen folks say to get multiple chains so you can swap when one gets dull.
How would I maintain it or set it up for sitting far a year or two?
Thanks for the education.
Dantilla 03-26-2022 02:07 PM
Airplane gas.
I have a couple Stihl saws that sit for extended periods.
They always fire right up, as 100LL avgas lasts almost indefinitely.
No matter what quality, a saw won't last long if gas with alcohol sits in it for very long.
masraum 03-26-2022 02:11 PM
Originally Posted by Dantilla (Post 11647581)
Airplane gas.
OK, no airports nearby. Sounds like I'll need to drain any gas that doesn't get used.
flatbutt 03-26-2022 02:15 PM
I use Stihl as well. I have the 150 C which is older and eats whatever I feed it. IDT they're still available but the 170 series might suit you with a 12" bar. They're usually under $200. I run them dry and store them that way. I always have a sharpened chain on deck.
https://bassanipowerequipment.stihldealer.net/products/chain-saws/homeowner-saws/ms170/
masraum 03-26-2022 02:19 PM
Thanks. Good to know.
So you're not thinking that I need one of these?
:D
<iframe width="560" height="315" src="https://www.youtube.com/embed/u17ll043Ld8?start=10" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
rfuerst911sc 03-26-2022 02:21 PM
Go with a saw you can get serviced locally . Stihl/Echo/Husqvarna are all good saws and they make homeowner quality and pro quality . My wife bought me a 16" Poulan years ago and I am surprised how well it has held up .
To me 16" bar/chain is a good size for a homeowner . I have three chains so I rotate out dull as needed . For engine size go 38 - 45 CC. Anything larger than that the weight can start getting up there .
NEVER EVER use ethanol fuel . Period . Use non ethanol mixed to correct 2 cycle ratio . If the saw is going to sit for more than about two months either add fuel stabilizer or run the saw out of fuel . I have never had an issue with restarting after following those rules . Good luck
Baz 03-26-2022 02:23 PM
I like my Echo CS 400. Use non-ethanol gas and you should be fine.
flatbutt 03-26-2022 02:25 PM
:D
I've been to those fairs in New Hampshire, they are a hoot!
pwd72s 03-26-2022 03:15 PM
Echo here as well. 16" bar. It's served well. Ditto on the no booze gas.
LWJ 03-26-2022 03:23 PM
Pure gas aka boat gas. I swear by it.
I have a mid level Husqvarna- nicer than you get at a big box store. Super light and easy to handle. Has a narrower gauge chain than typical so less power to cut. Down side? Probably need to sharpen more.
I have had it 17 years or so. Bought it when I got the house with 70+ maples. Use it every year but not much. Critical piece is will it start.
It has been a rock star!
masraum 03-26-2022 04:21 PM
How do you guys find gas with no corn? The nearest gas station that I know of with no corn gas is 50 miles away.
cabmandone 03-26-2022 04:24 PM
Bought the Dewalt battery powered saw. The thing kicks ass! My dad and I used it a few weeks ago cutting up a dead Ash that the wind blew over. For a gasser, I'd go Poulan if your just using it occasionally. My brother has one and it works well.
http://forums.pelicanparts.com/off-topic-discussions/1106997-battery-powered-chainsaws-yikes.html
flatbutt 03-26-2022 04:35 PM
I can't get no corn fuel. My Stihl has always used whatever the local BP sells and I've never had a problem. But I ALWAYS run it dry.
For once a year use you could buy the pre mixed fuel that shops sell at 10x the price of pump gas rather than mixing a gallon that you won't use. It's usually 50:1 and ethanol free but very pricey.
cabmandone 03-26-2022 04:38 PM
You can buy the premix from Husqvarna or Stihl but it's EXPENSIVE.
vash 03-26-2022 04:52 PM
You described my use. I bought an ECHO maybe 15 years ago. Occasionally used. It’s a great saw. CS45 or something with a 16” bar.
I run non-ethanol after I had a fuel line ear thru with the other stuff. Easy fix. Cost me $50 at a pro shop. The guy did marvel at how well my saw ran, after he was done. I buy non ethanol. A gallon of the store bought premix stuff is $15 and last so long with me. I only run the saw, but more often my blower. I run the saw dry and put it away. Zero issues. Except wgat I mentioned earlier.
steve185 03-26-2022 04:59 PM
Stihl is what I use, let it run out of gas when going let it sit for a while and it won't let you down.
steve185 03-26-2022 05:02 PM
Does all pump gasoline in the USA have ethanol?
masraum 03-26-2022 05:09 PM
Nope
There is a Bucc-ees about 50 miles from me that sells alcohol free gas. I think it's 91 or 92 octane and about $1/gal more than 93 octane gas with corn.
OK-944 03-26-2022 05:36 PM
Echo here also...great power to weight ratio as well.
Baz 03-26-2022 05:43 PM
For a while it was the Marathon station on US 1, but then a Wawa went in on SR 44, so that's where I get mine.
I also fill up some large fuel cans to have during hurricane season but also use those to make my 2-cycle mix for all my handheld power equipment, which is mostly Echo brand.
I also use non-ethanol in my motorcycles and vintage Porsches.
The Silverado gets the regular stuff. :)
