If you are only dealing with 18" diameter stuff occasionally, then those little saws with the 16" bars will still get the job done. And they are lighter. Size matters.
Buy a Stihl and be done with it.
I own 4 or 5. |
^^^ Go big or go home!
One of the local dealers usually has a big azz Stihl with a 5' bar on display .... I don't even know the model .... I go home :D |
Stihl makes 3 different levels of products. 1)Homeowner 2)Mid level 3) Professional
I have a mid level saw, Farm Boss. If you feed it Stihl gas they package, they'll extend the warranty another full year. Like anything else, buy more saw than you think you need. Mine is bad@ss and the fuel smells like race gas out the exhaust. It's been rock solid, the only thing is I go through chains as because of what I'm cutting. |
^^^ LOL .... that's a cutie pie Steve....
http://forums.pelicanparts.com/uploa...1648410622.jpg All of them (even the small Echo) wear the yellow coded Stihl chains, or full chisel Oregon. I don't have my 13' Stihl pole saw here, but it came with their POS green bar & chain ... WTF? Cost another hundred to transform it from a butter knife into a serious saw.... and worth every cent. No matter what saw ya pick... the chain is what matters :). A chain that touches dirt .... just needs sharpening .... mebbe even on a bench sharpener, but certainly not ready to be tossed. Supe is nutz ;) For bigger stuff than what my saws will do easily.... I call "the man", but 3-4' oaks are common here and these have seen their fair share :D |
The next chain I purchase will be a full chisel. Never tried one but I hear their cut is superior .
My Bauer will cut 3-4" oaks also. :) |
This guy's somewhat of an expert. An early Stihl perhaps?
http://forums.pelicanparts.com/uploa...1648415784.jpg |
My two main saws see the most use, and they have yellow Oregon chains. The best sharpener is the electric one that you bolt to a work bench. It has a little cutoff disk, and you use it like a miter saw. It's fast and works well. |
I have a thirty year old husqvarna 45 with a 20 inch bar. Thing has been rock solid. However, it being so old that parts are hard to find. I’m going to buy a Stihl ms261 soon. It’s a pro saw but with the tree situation I have I’m going to put it to good use.
I have one of these also, which I use mostly for pruning but also construction. Like when I was building my decks here to saw off a 2x4 or 4x4 or whatever needs it.
Cordless and you can use it with only one hand. I use these 12" carbide pruning blades, but you can use whatever standard sawzall blade you want. It's called a "HACKZALL".......and you want the M-18 "Fuel", which has the brushless motor. Milwaukee 2719-20 M18 FUEL Hackzall (Bare Tool), Red, Black https://i.ytimg.com/vi/QwnolLoC1rk/maxresdefault.jpg https://www.acmetools.com/on/demandw...7B22CBE9_7.jpg |
I've also got one of these. I probably need to sharpen the chain. It is impressive, but not really adequate for my needs.
https://2e1293630802db8d0d56-50fcdb1...22bc262dd4.jpg |
| All times are GMT -8. The time now is 07:13 AM. |
