When are lawn tractor tires bad
We've got a zero turn that's about 4 years old. It's not uncommon for the back tires to spin which is a pain when trying to maneuver. Is that normal or an indication that they are old and need to be replaced?
Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa ![]() |
Zero turns will spin the tires easily if proper turning isn’t used and will also rip up grass. My zero turn is 4 or 5 years old and tires are fine and that’s cutting about 3 acres per cut. Try smoothing out your turns.
https://youtu.be/iClPprJ7Olg This might help.
Spinning is a factor of the tread profile on a zero turn. I have a large Kubota zero turn that, in certain conditions, spins rear tires like a DJ spins records. The dealer recommended against a more aggressive tread profile.
I have learned to pivot less aggressively on specific lawn conditions...may not be your problem, but it was mine. Much less spin. I love zero turns! Mine got the pre-season check-out yesterday and will get out next week. I have some smaller MF tractors I bought twenty years ago that still have their original tires.
1996 FJ80. |
OK. I've kind of assumed it was just the nature of things, but wanted to confirm. And this mostly happens in odd/unusual circumstances, not on flat, level ground when doing normal mowing.
And yes, ours has the "lawn friendly" tires.
Load them?
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
When you do need tires consider ATV tires . You can get more aggressive tread pattern without going crazy . Then load them with windshield washer fluid you will be good to go. You still have to maneuver smartly but tread plus weight is the way to go .
Also climbing-I have a steep area next to the house that stays damp in the shade, gotta ease up the over the top or I can get a little spin in the combined turn/climb, but you can creep without slowing the deck down, which is the beauty of a zt.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
Kessel run in 12 parsecs!
Id purchase some new ones, you will get the vehicle running like new with fresh sneekers.
Getting old sucks, bring back the good old days, this new stuff is for the birds.. |
The rears seem OK, so I'll probably leave those for now.
