-   -   Stuck oil filter. (http://forums.pelicanparts.com/off-topic-discussions/1115660-stuck-oil-filter.html)
Arizona_928 03-27-2022 06:52 PM
Stuck oil filter.
Saw this on the ole reddit. Enjoy! http://forums.pelicanparts.com/uploa...1648435878.jpg
john walker's workshop 03-27-2022 07:04 PM
Hate it when that happens.
Arizona_928 03-27-2022 07:07 PM
note the direction of the buckle. ;)
craigster59 03-27-2022 08:31 PM
Bang a large Phillips screwdriver through it and crank clockwise, that'll get it off.....
RANDY P 03-27-2022 08:58 PM
^^^^ what I do.
rjp
Arizona_928 03-27-2022 09:22 PM
You're a menice to society!
Bill Douglas 03-27-2022 10:26 PM
Unscrew is anticlockwise.
pwd72s 03-27-2022 10:44 PM
Sure looks like clockwise was used. ;)
rfuerst911sc 03-28-2022 03:25 AM
Righty tighty lefty loosey 😁
masraum 03-28-2022 04:25 AM
That usually works, but many years ago (35), I had that just result in the bottom of the filter ripping off. I ended up having to use a cold chisel or regular screwdriver to pound the flange at an angle to get the rest of the filter off. It was the result of taking a car to an oil change place.
KFC911 03-28-2022 04:32 AM
Yer a bad man .... a very, very bad man ;)!
First time removing the filter after acquiring my 911... that sucker was not budging. First with the proper "thingy" that fits over the end of the filter, then I bought a filter "strap wrench", then I resorted to a big screw driver punched through the filter.... that just mangled the filter, but still stuck .... ALL while turning counter-clockwise, and I just had a mangled mess on my hands.
I then bought a pair of "Big Azz" channel lock pliers (yes, that name is stamped on them) and got that sucker off :)
http://forums.pelicanparts.com/uploa...1648470949.jpg
sc_rufctr 03-28-2022 04:32 AM
I have a small collection of strap tools and LARGE sockets so I rarely have an issue but the screw driver through the side trick has saved me a few times. The newer screw on plastic caps work well but it's really easy to scar them.
Bob Kontak 03-28-2022 04:44 AM
Originally Posted by KC911 (Post 11648770)
Tijuana Speed Wrench
+1
Screwdriver trick has failed on me more than it has worked.
Fast Freddy 944 03-28-2022 05:28 AM
Probably went over his oil change limit and it cooked on, that or the dummy buggerd it up and tightned it instead of loosened it..
Norm K 03-28-2022 05:29 AM
As long as there's room to rotate the spear this is a quick and clean method.
Well, it's quick anyway ...
_
KFC911 03-28-2022 05:46 AM
_
I challenge anyone to use a screwdriver and remove a stuck filter by turning it clockwise! Unless you have left-handed clocks :D
john70t 03-28-2022 06:01 AM
It works on bicycle cranks and some truck lugs. Turns it brand new.
GH85Carrera 03-28-2022 06:10 AM
After 30 years 375,000 mile on my El Camino I have done a lot of oil changes. Only once have I had a problem getting the filter off. It turns out the dummy that put the last filter on (me) did not inspect the old filter very well. It left the rubber gasket behind on the engine. The new filter just added in a second gasket. For whatever reason the two gaskets bonded and made a crazy seal. I tried my oil filter wrench, and two different strap wrenches. I finally had to get a chain wrench that really bit down on the filter and a long pull handle to get it to let go. When I got it off, I saw two rubber gaskets and really cussed at the dumb MF that did not check the engine before putting on the new filter. Now I double check it is just a film of oil on the engine where the filter screws on. And it sure gets a nice coating of oil on the rubber gasket.
For my wife's Macan, the filter is a cartridge. The housing has a 32 mm nut on top. It has two paint parks, on on the housing top, and one on the bottom. Tighten to there, and it simply stops. Very easy to do.
craigster59 03-28-2022 07:09 AM
Channel Lock actually makes a filter wrench/pliers. They work great.
berettafan 03-28-2022 07:15 AM
Just taught my son that trick last week. Did his first oil change and that beech wasn't moving and my filter socket didn't fit.
