-   -   Removing a snapped and sunken bolt (http://forums.pelicanparts.com/off-topic-discussions/1117071-removing-snapped-sunken-bolt.html)
pwd72s 04-17-2022 12:12 AM
Good video..
https://www.youtube.com/watch?v=dJfkCj3FWBs&ab_channel=UltimateHandyman
Chocaholic 04-17-2022 06:08 AM
I am hereby proclaiming that I will never find myself in need of such skill, so will dutifully avoid watching the video.
So, what are the odds I’ve just jinxed myself?
DavidI 04-17-2022 06:38 AM
Thanks for posting! I never thought of center drilling a bolt to use as a guide. Great info, David
VINMAN 04-17-2022 06:43 AM
Perfect timing.
I snapped a head bolt on one of my outboards last night.. :mad:
GH85Carrera 04-17-2022 06:53 AM
That is neat, but I don't have a lathe to make a drilled out bolt to center the drill bit. I wonder if anyone sells a set of bolts that are drilled out for drilling a broken bolt. Of course I would need a set for SAE and Metric.
Or better yet, avoid breaking any bolts!
billybek 04-17-2022 06:58 AM
That is a great idea!
Thanks for posting the video.
<iframe width="560" height="315" src="https://www.youtube.com/embed/dJfkCj3FWBs" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
svandamme 04-17-2022 08:16 AM
if you use an axle grinder , you can get it removed pretty easy, especially in aluminium the grinder goes through it like butter, just a single cut along the lenght of the bolt usually does the trick
pwd72s 04-17-2022 12:57 PM
I wondered the same. Hint: Could make a nice little side biz for somebody here with a good lathe. Sell a set of the more common metric and SAE sizes.
svandamme 04-17-2022 01:27 PM
You dont need a lathe for that. A good drill press and a bit of centering will get you there just as well
A930Rocket 04-17-2022 03:36 PM
What is he have so many broken bolts to begin with? lol
McMaster has a few vented bolts that would get you started.
Screws
https://www.mcmaster.com/Screws/vented-hex-head-screws
oldE 04-17-2022 03:43 PM
Just hit the broken bolt with a punch to start your bit. Takes seconds and works.
One size fits all.
Best
Les
john70t 04-17-2022 11:19 PM
iff'n you want to get fancy, there is EDM https://forums.pelicanparts.com/search.php?searchid=23998599
Whacking the face of a bolt with a hammer, a little heat around it, turn in a hair and then out, impact, always helps.
bob deluke 04-18-2022 02:42 PM
To bad none of these tools will remove my broken spark plug threaded section.
pwd72s 04-18-2022 03:31 PM
This on a Ford F-150? if so..
https://www.amazon.com/Lisle-65700-Broken-Remover-Engine/dp/B00SQ4FSN6/ref=asc_df_B00SQ4FSN6?tag=bingshoppinga-20&linkCode=df0&hvadid=80333123589171&hvnetw=o&hvq mt=e&hvbmt=be&hvdev=c&hvlocint=&hvlocphy=&hvtargid =pla-4583932709120767&psc=1
HobieMarty 04-18-2022 03:58 PM
Spring loaded center punch and left handed drill bits work fine from my experience anyway. Good video though, it's always nice to have options.
fastfredracing 04-18-2022 06:19 PM
I have a couple sets of these, slicker than you know what
<iframe width="560" height="315" src="https://www.youtube.com/embed/SGx7DsPX4nc" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
bob deluke 04-18-2022 07:19 PM
Pwd:
Wish it were that easy. Plug snapped at the threaded portion in my 2010 Cayman. These won’t work.
pwd72s 04-18-2022 09:06 PM
Originally Posted by bob deluke (Post 11669588)
Pwd:
Damn...so gotta pull the head? Ouch! $$$$.
pwd72s 04-18-2022 09:10 PM
That's cool!
