pwd72s's Avatar
Removing a snapped and sunken bolt
Good video..
https://www.youtube.com/watch?v=dJfkCj3FWBs&ab_channel=UltimateHandyman
Old 04-17-2022, 12:12 AM
Registered ConfUser
I am hereby proclaiming that I will never find myself in need of such skill, so will dutifully avoid watching the video.
So, what are the odds I’ve just jinxed myself?
Mike
Old 04-17-2022, 06:08 AM
DavidI's Avatar
Thanks for posting! I never thought of center drilling a bolt to use as a guide. Great info, David
99 996 C4
11 Panamera 4S
83 SC Targa converted to a 964 cab (sold)
67 912 (sold)
58 Karmann Ghia choptop (traded for the 912)
Old 04-17-2022, 06:38 AM
Parrothead member
VINMAN's Avatar
Perfect timing.
I snapped a head bolt on one of my outboards last night..
Vinny
Old 04-17-2022, 06:43 AM
That is neat, but I don't have a lathe to make a drilled out bolt to center the drill bit. I wonder if anyone sells a set of bolts that are drilled out for drilling a broken bolt. Of course I would need a set for SAE and Metric.
Or better yet, avoid breaking any bolts!
Old 04-17-2022, 06:53 AM
UnRegistered User
billybek's Avatar
That is a great idea!
Thanks for posting the video.
Bill K.
Old 04-17-2022, 06:58 AM
Gon fix it with me hammer
svandamme's Avatar
if you use an axle grinder , you can get it removed pretty easy, especially in aluminium the grinder goes through it like butter, just a single cut along the lenght of the bolt usually does the trick
Stijn Vandamme
BIMDIESELBMW116D2019
Old 04-17-2022, 08:16 AM
pwd72s's Avatar
I wondered the same. Hint: Could make a nice little side biz for somebody here with a good lathe. Sell a set of the more common metric and SAE sizes.
Old 04-17-2022, 12:57 PM
svandamme's Avatar
You dont need a lathe for that. A good drill press and a bit of centering will get you there just as well
Stijn Vandamme
Old 04-17-2022, 01:27 PM
A930Rocket's Avatar
What is he have so many broken bolts to begin with? lol
McMaster has a few vented bolts that would get you started.
Screws
https://www.mcmaster.com/Screws/vented-hex-head-screws
Old 04-17-2022, 03:36 PM
Kantry Member
oldE's Avatar
Just hit the broken bolt with a punch to start your bit. Takes seconds and works.
One size fits all.
Best
Les
Best
Les
Old 04-17-2022, 03:43 PM
You do not have permissi
john70t's Avatar
iff'n you want to get fancy, there is EDM https://forums.pelicanparts.com/search.php?searchid=23998599
Whacking the face of a bolt with a hammer, a little heat around it, turn in a hair and then out, impact, always helps.
Old 04-17-2022, 11:19 PM
To bad none of these tools will remove my broken spark plug threaded section.
Old 04-18-2022, 02:42 PM
pwd72s's Avatar
This on a Ford F-150? if so..
https://www.amazon.com/Lisle-65700-Broken-Remover-Engine/dp/B00SQ4FSN6/ref=asc_df_B00SQ4FSN6?tag=bingshoppinga-20&linkCode=df0&hvadid=80333123589171&hvnetw=o&hvqmt=e&hvbmt=be&hvdev=c&hvlocint=&hvlocphy=&hvtargid=pla-4583932709120767&psc=1
Old 04-18-2022, 03:31 PM
HobieMarty's Avatar
Spring loaded center punch and left handed drill bits work fine from my experience anyway. Good video though, it's always nice to have options.
Wonka
Old 04-18-2022, 03:58 PM
fastfredracing's Avatar
I have a couple sets of these, slicker than you know what
No left turn un stoned
Old 04-18-2022, 06:19 PM
Pwd:
Wish it were that easy. Plug snapped at the threaded portion in my 2010 Cayman. These won’t work.
Old 04-18-2022, 07:19 PM
pwd72s's Avatar
Pwd:
Damn...so gotta pull the head? Ouch! $$$$.
Old 04-18-2022, 09:06 PM
pwd72s's Avatar
That's cool!
Old 04-18-2022, 09:10 PM
