My other ride is a C-130J
RNajarian's Avatar
Yes it would be very easy to cap it off. Literally shut the valve supplying the water.
I do like the idea of a sprinkler system protecting my two 911s
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 05-04-2022, 05:01 PM
Control Group
Tobra's Avatar
How much water damage would it do if that went off?
Old 05-04-2022, 06:05 PM
RNajarian's Avatar
The interior is dry walled, books, pinball machines etc . . . If the sprinklers went off there would be $15,000-$20,000 in damage easy.
. . . but my 911s are in there too. Combined those are worth more than $20,000. I’m thinking a soggy garage is better than baked 911s
Grandma and the boy in a pinball tournament
Grandma and her Brother playing
1975 911 3.0
2000 996 2S
Old 05-04-2022, 06:47 PM
RNajarian's Avatar
Here is a pressure timeline. . .
May 4
8:00 am : System pressure 85 PSI. PRV Pressure at factory setting 85 PSI
3:00 pm : Recorded ambient outside temperature 81.5 deg F
5:00 pm : System pressure 146 PSI
8:20 pm : System pressure 106 PSI
May 5
3:00 am : Recorded outside ambient temperature 54.5 deg F
7:00 am : System pressure 85 PSI; Recorded outside ambient temperature 56 deg F
1:00 pm : System pressure 120 PSI; Recorded outside ambient temperature 77.5 deg F
3:45 pm : System pressure 140 PSI; Recorded outside ambient temperature 79 deg F
8:00 pm : System pressure 110 PSI; Recorded outside ambient temperature 71 deg F
9:00 pm : System pressure 100 PSI; Recorded outside ambient temperature 67 deg F
May 6
8:00 am : System pressure 85 PSI; Recorded outside ambient temperature 62 degrees F
Likely the heat of the garage attic where the pipes are caused the pressure increase.
The trick will be monitor temperature on a very hot day and on a very cold day.
Maybe I need an expansion tank after all. It is likely I never noticed the wide range of temperatures all these years. It makes sense the pressure rises with the heat of the garage attic during the day. I was thinking of putting an attic fan to keep the garage cool. That would keep the pipes in the ceiling 20 degrees cooler during the heat of the day.
Last edited by RNajarian; 05-06-2022 at 05:21 PM.. Reason: Adding Pressure/Temperature info
Old 05-04-2022, 08:27 PM
RNajarian's Avatar
UPDATE:
It is pretty obvious high attic temperatures would have an effect on pressure of the fire sprinkler pipes.
Likely the system has been cycling for the past 20 years high and low pressure depending on those attic temperatures.
I installed a thermostat controlled attic fan today and placed a wireless temperature sensor inside the attic. Hopefully the fan will keep the attic cooler and prevent the high 150 PSI I was seeing on the system.
Time will tell.
Old 05-08-2022, 09:04 PM
Make Bruins Great Again
Por_sha911's Avatar
"Automatic Fire Suppression"
I thought you got yourself a machine gun with a silencer.
Joe
Old 05-09-2022, 03:43 PM
