Wifi security question
The other day I installed a Rachio 3 irrigation controller. It needs to be connected to a WiFi so I can setup the water zones. I went through the process on my iphone after downloading the app and an error came up. The app didn't ask for a password. I backed up a few steps in the app and all of sudden it seemed to be connected to the WiFi. In the mean time somewhere I pushed a button on the front that had a WiFi symbol near it. The button is not mentioned in the instructions or on the app. How does this work that something can connect to my WiFi without a password?
Thanks.
Sold: 1989 3.2 coupe, 112k miles |
Your IoT device (irrigation controller) has a protocol, Read about device management
https://www.iotforall.com/glossary-iot-standards-and-protocols Now your landscaper can access your bank account, welcome to the cyber security world.
1980 911 - Metzger 3.6L 2016 Cayman S |
Sounds like you've got something on your router protocols set up as always broadcasting open. That's the first thing I'd look at.
Guy '87 944 (first porsche/project car) |
I wonder if it would have needed your password if you were setting it up from a place where you weren't connected to your own wifi.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Wonder how easy it is to get the MAC address of your IoT thing.... since that is how I handle wifi security...
Is it possible that since your phone already has permission to use your WiFi that the app automatically gets it too? Maybe have a friend try their phone to see if it just connects as well?
Rutager West 1977 911S Targa Chocolate Brown |
That's a yes/no answer. Typically, when you set up an app for a device, you have to first pick a network and input the password the first time. After that, the app is just like any other "device" you've allowed to access your network.
logged into the router via 10.0.0.1 and could not find e.g. WPS, WPA, WPA2 settings. ??? more internet digging needed.
okay found it.... both 2.4 and 5 GHz are set to WPA2 PSK AES
The Unsettler
The device does not have open access. The app controls it all and you approved the app for access. Without the app as a proxy the device can't connect. And FWIW, if you don't have a Rachio you need one.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
okay - I don't fully understand. Something like since the app on my iPhone said it was okay to join the network the device supported by the app is also given access. I'm assuming there is no way or at least difficult for someone to see the traffic or get access to my Wifi by being associated with Rachio. Case closed?
